How to disconnect hatch pull down black wire to motor and contact sensor?
Old Jun 25, 2023 | 10:27 AM
Ragtop Man's Avatar
Started the barnfind Formula 350 (aka 'Freebird') and the hatch motor started humming loudly - but no pulldown action.
Popped the rear plastic panel to disconnect the pigtail. White terminal with the multi-wire harness to the assembly came off after tickling the barbs with a small screwdriver.
The single black wire to motor wasn't budging, nor was the connector with the harness to the contact sensing plate.
What is the best method to get these off so I can pull the panel for cleanup and get the assembly on the bench?
1986FirebirdV6
Mid-West Region
Aug 27, 2016 02:00 PM
bbsr72
Apr 22, 2007 01:26 AM
seymourless
Oct 11, 2006 09:23 PM
dirtybird
Oct 12, 2002 11:06 AM
iceman02
Mar 25, 2002 11:51 PM
