Center lid RPO Coded
Old Apr 10, 2024 | 12:04 PM
Shaunejulian's Avatar
Car: 1986 Blue Iroc Z TTop
Engine: 305 LG4
Transmission: 5speed
So I am wanting to replace my center lid on my 1986 iroc because the sides have buckled out. However I don't want to lose my RPO codes. Is there somewhere they remakes the sticker for my codes I could put in the new lid?
Old Apr 10, 2024 | 05:35 PM
topduarte's Avatar
Car: 92 Heritage Camaro Z28
Transmission: auto
Axle/Gears: 3.23 Limited Slip
Re: Center lid RPO Coded
Get someone to scan it and reprint it for you.
Not hard to do
Old Apr 10, 2024 | 08:13 PM
LAFireboyd's Avatar
Axle/Gears: 9-bolt/3.45
You can't peel off the original sticker and stick it on the new lid? Sounds like you have it. They come off pretty easily without being damaged.
Old Apr 10, 2024 | 09:06 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
A heat gun will soften the adhesive. Doesn't take much heat to remove.
Old Apr 12, 2024 | 11:27 AM
Engine: 305 LG4
Appreciate it. I will try that and just glue it back into my new lid.
Old Apr 12, 2024 | 12:27 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Go easy on it though. Its easy to burn the label, 10-30 seconds and the adhesive goes soft.
Old Apr 17, 2024 | 02:35 PM
my82roc's Avatar
Car: 89 Iroc Convertible
I used a hair dryer to peel mine off when I swapped consoles in my iroc
Old May 5, 2024 | 06:30 PM
Engine: 305 LG4
So I figured out a better way. I bought a new center console lid from hawks. I took off the underside of the lid off my old one that had my rpo codes. I then took out the underside lid on the new one and replaced it with my original one. Now I have a new lid with my original rpo codes in it
The Real Mr.Blu
Apr 9, 2020 10:30 PM
87TPI-5SPD-TA
Apr 7, 2010 06:08 PM
cmaro-8
Mar 7, 2009 10:04 PM
Not Danny
Dec 2, 2005 05:51 AM
Shibbyfbird
Apr 29, 2002 01:30 PM
