Replaced odometer gear and now speedo stopped working
Old Jul 14, 2024 | 07:42 PM
88BLKTransAmGTA's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7 L98
Axle/Gears: 3.77
1988 trans am GTA with 140 speedo.
My odometer quit working because of the plastic gear giving out like normal so I replaced the gear, put everything back in and now my speedometer and my odometer isn't working. What's the first thing I need to check? Was super simple swapping the new gear in so I don't think that is the issue. All other gauges are functioning except this one. where to i check first?
Old Jul 14, 2024 | 08:56 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Re: Replaced odometer gear and now speedo stopped working
Unhook the cable down at the gear and spin the end of the cable with a drill, see if the speedometer does work. Maybe a broken cable if it doesn't. Was the new gear the same color as the old one?
Old Jul 15, 2024 | 06:18 AM
Engine: 5.7 L98
Axle/Gears: 3.77
Is there a cable? I thought after 86 the firebird was electronic?
The gear was not the same color. But im sure the original one was white at one time. My car only has 84,000 miles.
I got the gear from odometergears.
Old Jul 15, 2024 | 07:54 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
The motor may have burned out if the gear was stuck to the shaft and teeth didn't break. Happened to one of my 89s
Old Jul 16, 2024 | 04:54 PM
Engine: 5.7 L98
Axle/Gears: 3.77
Teeth did break and speedo was still working after that I just noticed the odometer wasn't spinning. Now after the gear replaced neither work
Old Jul 17, 2024 | 06:21 AM
Engine: 5.7 L98
Axle/Gears: 3.77
Took it back out. Looks like all teeth are good. I can spin the screw on the motor with my finger and odometer and trip move. I'm guessing I need to replace the board to the motor because I'd the motor fails then the speedometer should still work right? If they both aren't working than that makes me think board. I don't see any burn marks on the board though
Old Jul 17, 2024 | 05:28 PM
Engine: 5.7 L98
Axle/Gears: 3.77
Is there a way to test the motor and circuit board to rule them out?
Old Jul 23, 2024 | 08:21 PM
Engine: 5.7 L98
Axle/Gears: 3.77
Bump! Still needing to figure out the issue
Old Jul 26, 2024 | 11:33 AM
Extrafitkid's Avatar
Car: 1986 TRANS AM
Engine: LB9
If You need a temporary Speedo Remember your phone has an app you can download. If you're afraid of tickets while you fix it.
App search: Speedometer GPS based but it works
Old Jul 27, 2024 | 09:11 AM
72buickgs's Avatar
Car: 1984 Trans AM
Transmission: 700-4r
In my 1984 T/A - the speedometer works fine. The Odometer works fine. The tripmeter works fine. However, I cannot reset the tripmeter to 0. Push the shaft in&/or turn the **** - not working. Fix?
mav75
May 2, 2015 10:11 PM
scoflaw
Apr 15, 2014 01:26 PM
92firebirdLT1
Feb 19, 2011 07:20 PM
dyed
Feb 22, 2008 09:18 PM
