Speedometer Questions
Old Sep 12, 2024 | 03:40 PM
72buickgs's Avatar
Car: 1984 Trans AM
Transmission: 700-4r
1) do i have to remove the dash to get at the speedometer?
2) is the speedo cable housing removable from the back of the speedometer or is it fixed/attached?
3) If I chose to remove the speedo cable from the speedometer by removing it at/from the transmission (700R4), is it did is it difficult to reinstall it from the trans point?
Think i need to relube cable.
Old Sep 12, 2024 | 04:15 PM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Re: Speedometer Questions
1) No. Only the dash pad and instrument panel.
2) I don't think it's removable but I've never had a reason to try it.
3) Why would you ever want to do that? What would be the point. Disconnecting and re-connecting the speedo cable to the transmission is easy. ...
Old Sep 12, 2024 | 06:28 PM
Aaron R.'s Avatar
Car: 1985 Z28
Engine: 305 LG4
1. No, but lowering the steering column and removing instrument cluster is about easiest way I have found.
2. Yes, it is removable. A clip holds it to back of speedometer.
3. No, not difficult. You can pull the cable itself out from transmission end, lube it, put it back in. This may not apply if you have the old 2 piece cable though.
Old Sep 13, 2024 | 08:47 AM
72buickgs's Avatar
Car: 1984 Trans AM
When the car is cold, and I begin driving, there is a noise coming from the speedometer. No noise in warm weather. I will remove the cable & lube it with white lithium grease as I have done to another car years ago.
Old Sep 13, 2024 | 10:34 AM
NCC-2569's Avatar
Car: 1990 Trans Am
Axle/Gears: Stock
Is your odometer clicking and not moving when it's cold? I used to have that a while and once the interior had warmed up, it disappeared and the odometer started working again.
I guess that was some clearance issue between contracting and expanding plastic parts.
Old Sep 15, 2024 | 05:48 PM
72buickgs's Avatar
Car: 1984 Trans AM
NCC-2569
speed work just a little noisy when cold.
Old Sep 16, 2024 | 10:55 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
IIRC, the speedo cable will only come out from the dash side. The cable has a collar on that side that prevents it from sliding into the housing. I used to remove the cluster and spray lube down into the cable housing by partly pulling the cable out. You can see the collar at this point.
Old Sep 16, 2024 | 04:01 PM
Aaron R.'s Avatar
Car: 1985 Z28
Engine: 305 LG4
Was just thinking about this today and I believe you are correct about the collar preventing from coming out bottom. Last one I put in my Camaro had that collar I think.
Old Sep 16, 2024 | 04:49 PM
T.L.'s Avatar
Does the car have cruise control? If so, there are 2 speedo cables, and the one making noise is probably not the one going to the transmission...
Old Sep 17, 2024 | 09:01 AM
72buickgs's Avatar
Car: 1984 Trans AM
There is only one speedo cable & I have cruise control. speed is controlled by a cable connection to the carb from the vacuum box ( for lack of another word) when cruise is activated.
Old Sep 17, 2024 | 10:10 AM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
1982 and 83 used the old 1960s type cruise control with 2 pc cable. Firebirds use electronic speedo starting with most '86 models except base cluster though '87 or '88
steven72192
Apr 2, 2011 04:07 PM
Hick_101
Mar 17, 2009 07:01 AM
Tripper511
Feb 20, 2006 03:34 PM
8IROC8
Jun 29, 2004 11:42 AM
TransAm12sec
Apr 27, 2003 12:47 AM
