Center console lid
Old Jul 21, 2025 | 03:55 PM
Turchman's Avatar
Center console lid
I installed the lid from Classic Industries this Winter and it is really poorly made. The spring arm is held in with two pop rivets and pulled out and the hinge screws broke the plastic. It seems all the materials are very brittle. I ended up creating new hinge mounting points with an entire tube of two part epoxy where the original screws were. I made two rectangular molds around the area and filled them with epoxy. I am not going to use the spring and arm and will use a magnet to keep it closed. The spring produces too much force and there is no reinforcement to handle the forces.
Hinge mounting point
spring arm
spring arm
Old Jul 21, 2025 | 04:36 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
Re: Center console lid
Thanks for the warning!
Old Jul 21, 2025 | 04:46 PM
LAFireboyd's Avatar
Axle/Gears: 9-bolt/3.45
Good to know. I've got one standing by for when I put my interior back together. I got mine from Hawk's, but they're available from other sources too, so they're all probably made by OER and will have the same problem. I see the pop rivets. I just won't install the spring. My original has been broken for 20 years, so I'm sure I can get along without the spring lol.
Old Jul 21, 2025 | 09:28 PM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Yep. Unfortunately, reproduction parts usually suck...
Old Jul 22, 2025 | 08:44 AM
Turchman's Avatar
Just take the inner cover off and pour some epoxy around the screw mounting studs to reinforce them and don't connect the spring. I added a magnet to the bottom of the lid and a metal plate from Amazon on the top of the console.
Amazon Amazon
Keeps it from bouncing around
Old Jul 22, 2025 | 12:02 PM
Vanilla Ice's Avatar
Car: 92 Trans Am Conv
Engine: LB9
Axle/Gears: 3.08
Mine shattered within 100 miles.
they are absolute garbage.
neilcase
Feb 13, 2022 08:24 PM
KRUSS
Oct 4, 2020 06:21 PM
whostorm05
Mar 25, 2018 11:16 PM
J-(Chicago)
Interior Parts Wanted
Feb 15, 2012 11:15 AM
bgmoss
Mar 10, 2009 02:08 PM
