PCM connector replacement
Old May 18, 2005 | 04:32 PM
Jaysz28's Avatar
Car: 91 Firebird
Engine: 6.0
the 4 main PCM connectors are toast on my 95 LT1 harness. There are three broken wires, three broken connectors and a bunch of crimped wires. Rather than chase electrical gremlins, I'd rather replace them. Any idea where to get new connectors and pins?
Old May 18, 2005 | 04:44 PM
TexasLT1's Avatar
Car: '92 RS
GM
Old May 18, 2005 | 10:46 PM
Jaysz28's Avatar
Car: 91 Firebird
Engine: 6.0
I'm afraid of their prices.... maybe I can zip tie it together for the time being........ *ugh*
thanks
Old May 20, 2005 | 07:32 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
New connectors from GM will be a bit pricey. You can take a pair of dykes to the boneyard and cut off some replacement connectors. The pins are easily removed, so it would be no problem to transfer over the undamaged wires, then simply splice the "new" wires to replace whats damaged.
Old May 22, 2005 | 01:55 AM
Jaysz28's Avatar
Car: 91 Firebird
Engine: 6.0
Well I figured the prices would be high. My luck at the bone yards has been negligible, with most of the 4th gens I've found being gutted.
Will the pcm connectors for a V6 work by chance? Guess I should take a look the next time I'm there
-jason
Old May 22, 2005 | 10:48 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
PCM connectors are color coded. I "think" as long as you get the same colors, you should be OK.
Old May 22, 2005 | 12:56 PM
Jaysz28's Avatar
Car: 91 Firebird
Engine: 6.0
Well thats good to know, I'll check out a yard on tuesday
Old May 22, 2005 | 12:58 PM
Jaysz28's Avatar
Car: 91 Firebird
Engine: 6.0
dbl post
Old May 24, 2005 | 10:02 PM
Jaysz28's Avatar
Car: 91 Firebird
Engine: 6.0
Alright, snagged some connectors off of two different v6 4th gens at the junkyard, and a set of off a late model sunfire. They all fit in the bottle of my toolbox and worked fine. So now the PCM connectors are taken care of, now I can get back to the rest of the nightmare
So basically, the PCM connectors are universal. I did have to punch out some holes in the plastic backing on the ones from the Sunfire. They mount that PCM in front of the passenger tire......
I like how the colored plastic pops off and you can interchange the connectors as needed. Purty sweet and it saved me some bucks
thanks for the heads up B
-jason
Old May 25, 2005 | 03:49 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Glad you got it.
89GTAOz
May 16, 2020 09:31 AM
TheJoeY88
Dec 31, 2016 07:30 PM
NBrehm
Aug 25, 2015 11:49 PM
mizz0313
Aug 12, 2015 06:45 AM
92purpz28
Aug 11, 2015 02:30 PM
