3rd and 4th gen clytch hydraulics question.
Old Jun 21, 2007 | 07:38 PM
Mdenz3's Avatar
Car: 91 RS
Axle/Gears: 3.42 LSD
Is it possible to use a 3rd gen master cylinder with a 4th gen slave and line?
I need a new Master anyway and i'd like to get a 3rd gen one to hopefully fix the high engagement point.
Old Jun 21, 2007 | 08:55 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
Re: 3rd and 4th gen clytch hydraulics question.
yes, they will fit and work. that is what I did since I had a new master, got a used line and a new slave.
Old Jun 21, 2007 | 09:18 PM
Mdenz3's Avatar
Car: 91 RS
Sweet thanks for the info.
Old Jul 2, 2007 | 01:30 AM
1991 RS/SS's Avatar
Car: 1991 Camaro RS
Engine: 383 LT1
Axle/Gears: 4.10
I realize this is not exactly what you are asking, but just wanted to throw in my two cents. When I did my swap, I used new 4th gen pedals and a new LT1 4th gen master/line/slave pre-bled setup from GM and it works flawlessly and was a virtual bolt-in when switching my auto car to manual.
Old Jul 4, 2007 | 07:31 PM
fire350tpi's Avatar
Car: 1988 Pontiac trans am/gta
Axle/Gears: 3.23's
Would u happen to have the part number on that setup? Or the t-5 one?
Even a affiliated Gm dealership tells my friend in parts they all come seperatly
Old Jul 5, 2007 | 12:02 PM
TexasLT1's Avatar
Car: '92 RS
the master/slave cylinder from GM definitely comes together as one preassembled unit, that's why the price is so high on it.
Old Jul 5, 2007 | 05:05 PM
fire350tpi's Avatar
Axle/Gears: 3.23's
Unforchanetly not according to the Santilli Caddilac Center ( GM Parts depart.)
which is affiliated with the dealer i work for about 30 feet away lol
and when i had my parts dept. call over for them to check they said the slave and line come seperate, which i said to them that there was a pre assmbled unit. But they couldnt find it as of today.
a part number would probly help which is why im trying to locate one, but the search on the forums seemed to be ****ed up so :S
Old Jul 5, 2007 | 09:20 PM
Mdenz3's Avatar
Car: 91 RS
Try ebay, i got my clutch hydraulic setup their brand new for less than the dealer wanted.
Old Jul 5, 2007 | 10:15 PM
Engine: ls1, LB9
hum.... lets get this cleared up so no one else gets confused
Now these are all GM dealer ordered! (aftermarket parts will show and sell parts seperatly... although I have not seen the hoses on there own I am sure they are where???)
#1) hyd. slave and master come as one ready to install preassembled unit for thirdgens.
#2) Hyd. slave and master for only 93-97 f-body's are sold as ready to install preassembled units
#3) the 98-02 f-body comes as seperate units master is one with hose , the throwout bearing is sold on it's own and is the slave for this style trans.
Old Jul 6, 2007 | 02:04 AM
1991 RS/SS's Avatar
Car: 1991 Camaro RS
Engine: 383 LT1
Axle/Gears: 4.10
Sorry, I dont have any part numbers handy. I ordered the parts from Hawks Thirdgen for much more reasonable prices than I could get at local dealerships.
I just called hawks and asked Bruce for clutch hydraulics and pedals for a 94 Z28 and they sent me the right stuff for the job. Both parts were new GM parts. I dont remember for sure, but I think the pedals were around $120 and the hydraulics (master/line/slave combo setup) were about $140. Dont quote me on those prices as I am not sure on them.
Im using the hydraulics on a T56. Im not sure if the slave on that assembly is correct for a T5. I would assume it would work because I have heard of people using thirdgen T5 hydraulics on a T56 swap.
Old Jul 7, 2007 | 09:25 PM
fire350tpi's Avatar
Axle/Gears: 3.23's
thanks for posting back, i didnt know hawks sold them :P
Yeah, Im not sure if a t-56 will work but i suppose all i gotta do is ask bruce if i call down there.
it may be delayed for a bit though, im hopefully going to be doing a cam swap next week
Old Jul 17, 2007 | 12:32 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
93-95 (95 1st design) LT1 12557509 Clyinder CLU MAS & ACTR
95 (2nd design) 12559912 Clyinder CLU MAS & ACTR
As far as I can tell there were a few different part numbers for the 96-02 clutch hydraulics. The master and actuator are seperate numbers as far as I can tell. I can list them if you guys want them
1992rs/ss
16
Jan 28, 2016 09:58 PM
Warlocksirix
Sep 3, 2015 12:26 PM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
redmaroz
Aug 16, 2015 11:40 PM
Eagle223usa
Brakes
Aug 14, 2015 09:24 AM
