How much should I expect to spend rebuilding an LT1
Old Nov 14, 2007 | 10:43 AM
ItalianZ32's Avatar
I am looking into buying an LT1 to swap into my 92 Camaro RS. The only major change I plan on doing in the rebuild is changing to the hotcam. Other wise, the rebuild will be to just clean up the engine and paint it. How much should I expect to spend on gaskets and other such things.
Old Nov 14, 2007 | 11:08 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
It doesn't sound to me like you're talking about a rebuild, just a cam swap and clean-up.
A full gasket set will run about $100. If all you get are the gaskets to do the cam swap, about half or less of that.
Engine paint is about $7/can (may find it for less). You'll probably need two cans. If you completely remove all of the original paint, I'd suggest using an engine primer first, then the final coat. Engine degreasers, some paint thinner to remove oils from the surfaces, etc. Probably about $50 for all of that stuff.
Old Nov 14, 2007 | 02:22 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Re: How much should I expect to spend rebuilding an LT1
Actually the gasket set is closer to $200 (with head gaskets) since with the Fel-pro (only gaskets to use) are the new perma-seal blue rubber gaskets and work like a charm. IIRC the oil pan gasket itself was around $40 but the rest should be like five7 said.
Old Nov 14, 2007 | 04:01 PM
chevyowner02's Avatar
Car: 1992 camaro
Axle/Gears: 3:73
I am at
1. Resurface the block and crack checking it $80
2. Same for the heads $100
3. Pistons $125
4. Oil pump $ 35
5. Used cc503 cam $125
6. Rod,Main& cam bearings $70
7. Gasket kit $165
8. LE1 Heads $950 (Shipping and all)
9.Hearing it run (not yet) PRICELESS
Old Nov 14, 2007 | 04:06 PM
brandotron's Avatar
Car: 2002 Camaro z28
Axle/Gears: 2.73 stock, stock, stock
Originally Posted by chevyowner02
I am at
3. Pistons $125
4. Oil pump $ 35
7. Gasket kit $165
10. 30 pack $18.99
Old Nov 15, 2007 | 03:40 PM
Car: 1992 camaro
Axle/Gears: 3:73
11.piston rings $120
Old Nov 15, 2007 | 10:15 PM
Fei's Avatar
Fei
Car: 1989 Trans Am
Engine: 94 383 LT-1
Transmission: Tremec 3550
My block was thrashed when I got it.
Shop work was about 700 that was:
.30 over bore
deck block
fix main caps and rod caps due to spun bearings
deck block
deck heads
valve job
cam bearing press in
Pretty much everything that could go wrong happen to this engine. I'm suprised it was fixable. Heh I got the long block for free :-D
Then the HOT cam kit was 600ish gasket set was 210. New valve covers to clear the 1.6 rollers 100ish. Summit rebuild kit with heavy speed pro pistons 550.
I kinda went the cheap route on the rebuild kit. So about $2100 for me on the engine alone. The little things add up. I spent about 4k all together on my swap.
Old Nov 15, 2007 | 11:03 PM
five7kid's Avatar
ItalianZ32, could you please explain exactly what you intend to do in this "rebuild"?
You seem to be using the term very, very loosely. You were very vague in your description, but it sounded to me like you're planning on a cam swap and paint job - nothing more. Not exactly the conventional use of "rebuild".
If that's what you meant, then all this talk about rings and bearings and machine work is moot.
david068513
LSX and LTX Parts
Nov 15, 2015 11:37 PM
L0tuS
Oct 4, 2015 08:07 AM
david068513
Sep 13, 2015 11:24 AM
david068513
South East Region
L0tuS
Sep 4, 2015 11:16 PM
