5.3 and trans question
Old Nov 29, 2008 | 08:41 PM
ND4SPD86's Avatar
Car: 87 Buick Regal T
Axle/Gears: 2.56 blah
Will an F body T56 bolt a 99 5.3 I searched LS1tech and here and could really find an answer. I would like to find out before buying an engine.
Old Nov 29, 2008 | 08:47 PM
SheldonZ28's Avatar
Car: 89 IROC/05 RX8
Engine: LS1/LS1
Transmission: T56/T56
Axle/Gears: 3.42 GM/3.55 8.8
Re: 5.3 and trans question
Yes it will. Need LS1 T56 trans/clutch/hydaulics
Old Nov 29, 2008 | 08:54 PM
Spike-Z's Avatar
Car: IROC-Z
Engine: LSx
Axle/Gears: Fabbed 9"
What he said ^^
Old Nov 30, 2008 | 12:09 PM
Blownz28man's Avatar
Car: 92 25th anv z28
Engine: 346 TC78 Turbo
Transmission: 4L80E
Axle/Gears: 3.25 9"Nodular, Strange axles
I don't think it will. The flange on the crankshaft sticks out further on that year. I think till 01-02?? Its like a 1/4in.I dunno but it is deeper. Your flywheel will be back further. If you install a later model crank or ls1 crank it will. Bellhousing bolt pattern is the same.
Old Nov 30, 2008 | 07:17 PM
ND4SPD86's Avatar
I think I will continue to look around for an LS1 after the first of the year then.
Old Nov 30, 2008 | 09:44 PM
SheldonZ28's Avatar
Car: 89 IROC/05 RX8
Engine: LS1/LS1
It had a wider rear main seal surface pad until '02, IIRC the flywheel was positioned the same? I beleive it came further into the motor.
I know my '03 LM7 had the smaller width rear main seal surfact.
Old Sep 29, 2010 | 02:25 PM
88FormulaKiller's Avatar
Car: 1967 Firebird P.T.
Engine: LS3 4" Strkr 422ci
Transmission: MN12 6 speed
Axle/Gears: 3.73 8.5" 10 Bolt Eaton
old thread but basically 03 and up 5.3's will bolt to a 98-02 F-Body T56 correct?
Old Sep 29, 2010 | 03:02 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
the crank issue is not with the 5.3s, just the 6.0's. i've got a 99-00 5.3 bolted to a 4l60e that was in a 98 TA
Old Sep 29, 2010 | 03:04 PM
Ok, but what about the T56... im using a T56 from a 98-02 F-body with a 5.3 and i have the option of 02 or 03 year 5.3 engine....
Old Sep 30, 2010 | 10:13 AM
dynodanmanda79's Avatar
Car: 1989 IROC-Z, 1979 Malibu Classic
Engine: LSx 5.3
Transmission: MN12 6-speed, 4L60E
Axle/Gears: 4th gen 3.42
Yes your t-56 will bolt up to a 99+ 5.3. Like Dan said, the early 6.0's were the one's that had the different cranks.
84z96L31vortec
Aug 20, 2017 12:16 AM
E Rod
Aug 28, 2015 05:17 AM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
