Starting with the search
Old Jan 4, 2009 | 09:55 PM
ls1projectirocz's Avatar
Car: 03 Cobra
Engine: 4.6 DOHC
Axle/Gears: 4:10
Well good news...I found my roller. Needs a ton of work body,but the doesn't scare or detour me. I was wondering if I bought a complete z with a blown motor(since I'm going to build it) if it would be cheaper than piecing it all together. Also how hard is it to make a harness or can I just use the stock one from the other car? Is there any year to stay away from or a year that has benifets? I'm shooting for huge #s this time around.
Old Jan 4, 2009 | 11:03 PM
1piece@atime's Avatar
Car: 86 T/A
Engine: 5.0 TPI
Re: Starting with the search
Are you asking if it would be cheaper to build a blown motor in one car than it would be to build a motor and do a bunch of body work on a different car then the answer is yes. If the wrecked car has a built motor then the answer would be maybe. And if the huge number your shooting for is the amount of money you can put into a car to make it fast then you should be real happy.
Old Jan 4, 2009 | 11:07 PM
Car: 03 Cobra
Engine: 4.6 DOHC
Axle/Gears: 4:10
I'm sorry I shoud have clarified I've got a 86 iroc. The wrecked car I'm talking about is a 4th gen z or ss.
Old Jan 5, 2009 | 12:23 AM
iroc1793's Avatar
Car: 1987 Camaro Iroc-z
Engine: 305 tpi
Transmission: t5
id recommend getting the 99 up ls1 out of an f body the 98's had a bigger cam but heads that werent as good as the 99 and up heads.
Old Jan 5, 2009 | 01:11 AM
Car: 03 Cobra
Engine: 4.6 DOHC
Axle/Gears: 4:10
Thanks man....a guy just called trying to sell my a 6.0 with no accessories. I almost think a complete ls1 so I can swap the interior too and have everything I will need basically.
Old Jan 5, 2009 | 01:17 AM
iroc1793's Avatar
Engine: 305 tpi
Transmission: t5
yea a complete donor car is what most people look for i think who want to swap interior, drivetrain, rear, gas tank etc.
Old Jan 5, 2009 | 01:30 AM
Car: 03 Cobra
Engine: 4.6 DOHC
Axle/Gears: 4:10
The car gonna roll w/ the 305 for awhile. I'm gonna get my ducks in a row and build my motor and tranny. I'll just have to wait for the right donor car.
Old Jan 5, 2009 | 12:45 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
No difference in the heads from the '97-'98 than the '99+ except that the 99+ have centerbolt valve covers and the '97-'98 have perimeter bolt.
Old Jan 5, 2009 | 01:32 PM
iroc1793's Avatar
Engine: 305 tpi
Transmission: t5
99+ heads flow better than 97-98...
http://www.ls1tech.com/forums/genera...ls1-heads.html
Old Jan 5, 2009 | 03:11 PM
Klortho's Avatar
Car: 1987 GTA
Here's a large thread that goes through the differences in the LS1 engines
http://www.ls1.com/forums/showthread.php?t=27515
2. Cylinder heads and valve covers redesigned to have center bolts instead of perimeter bolts. Other than that, the heads were the same.
Old Jan 5, 2009 | 03:36 PM
Car: 03 Cobra
Engine: 4.6 DOHC
Axle/Gears: 4:10
Awesome thanks I really appreciate the help guys
Ghettobird52
Jul 5, 2024 11:18 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Juneb1022
Firebirds Wanted
Oct 12, 2015 08:12 PM
89redeyeRoc
Car Audio
Aug 24, 2015 07:01 AM
hokis
Aug 9, 2015 03:57 PM
