Is a VSS signal really necessary?
Hey everyone I would like to know if the VSS signal is really necessary with my application. I am swapping my 95 LT1 with a T-5 behind it(please refrain T5 sucks comments,I found one with trans,master cylinder,shifter and boot and virtually everything to go with it for 250,so I'm just gonna go with it).Anyways... I'm using the stock ECU and engine wiring harness. The donor car I got the LT1 out of was a manual(T56 was already sold) and I would just like to know how the ECU will react to not having a VSS signal. The reason I ask is due to the fact that the tranny I have is cable driven, along with my autometer speedo.
thanks for your help -Cameron
Car: 1987 Z28
Engine: 2005 5.3L, LS6 Cam
Axle/Gears: DTS 9" 3.50 TrueTrac
Re: Is a VSS signal really necessary?
I dont think it would matter as u are 5 speed and cable driven for ur speedo. As long as the computer is tuned for a manual I cant see an issue. An auto needs it to shift (when I rewired my car I hooked it up and plugged my speedo in wrong and the car wouldnt come outta first lol. All i did was pull the speedo out and switch the wires around and bam it shifted lol.
Jay
Jay
Car: 1986 Camaro IROC-Z
Engine: 357 LTx
Transmission: T-56 6spd
Axle/Gears: GM 7.5 10 bolt with 4.10 richmonds
Whenever your ready for another T-5 lol, I have one sitting around my garage I'll sell you real cheap.
Car: 87 GTA
Even a T5 ECM looks for a VSS signal. If it doesn't see one, it'll set off the CEL.
Not sure what tuning changes happen, if any, when the VSS signal is missing.
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
im no expert, but youll have an issue with cruise control.
i cant see any other reason everything wouldnt run right, except a check engine light.
I wonder if it would be worth it to just get the VSS programmed out of my ECU along with the VATS?Because I would like to have a properly functioning check engine light...
Car: '98 Mustang GT
Engine: '03 4.6L
Transmission: T45
Axle/Gears: DK
Another option is to build an interface cable, buy a program, and program it out yourself. Would need a soldering iron, solder, and good soldering/computer skills. Kind of explained it more in this link: https://www.thirdgen.org/forums/ltx-...-question.html
TMZIrocZ350
Oct 7, 2015 12:09 PM
