ls1 alternator question
Old Apr 15, 2009 | 10:39 PM
3.1EyeCandy's Avatar
Car: 1987 GTA
Transmission: 4L60e
Is it necessary to ground the alternator? Seems like a dumb question, but I've been thinking this over for weeks now after hooking a nice ground strap from a bolt on the alternator (not the charging post) to the body of the car. Here's what my power/ground situation looks like:
Thanks!
Old Apr 15, 2009 | 10:45 PM
Car: 1987 GTA
Transmission: 4L60e
Re: ls1 alternator question
Old Apr 15, 2009 | 10:55 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The starter is grounded to the engine, and the engine is grounded to the battery.
Old Apr 15, 2009 | 11:00 PM
Car: 1987 GTA
Transmission: 4L60e
That's what I was thinking too...the more I thought about it. Is it hurting anything to have the extra ground strap there? I'll take it off if needed...
Old Apr 15, 2009 | 11:13 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
the more ground wires the better throughout a chassis IMO. You can never have too many if you are running many electrical components.
Old Apr 16, 2009 | 10:36 AM
andrew69_04's Avatar
Car: 92 Camaro RS
the ls1 uses a small ground that runs from the side of the block (just behind the alternator) to the chassis. If your motor doesnt have that ground strap anymore, i would put a ground from the alternator to the frame.
Old Apr 16, 2009 | 06:44 PM
Car: 1987 GTA
Transmission: 4L60e
Good deal guys. I've got a hefty ground strap from the passenger rear head area to the body along with the one I mentioned on the alternator. "Ground straps" are surprisingly hard to buy around here...forget about going to an AutoZone or O'Reilly's - they don't even know what a ground strap is!
Old Apr 16, 2009 | 07:37 PM
xpndbl3's Avatar
Car: 1984 Z28
i just buy 12" long battery cables that have lugs on both ends.
Old Apr 16, 2009 | 08:30 PM
V8Rumble's Avatar
Car: '89 Trans Am GTA
Engine: WAS 350 - now L92 (alum. 378/6.2L)
Transmission: WAS 700R4, now a built T56
Axle/Gears: 3.27 9-bolt
No man, that's WAY too much extra weight for the front of your car, you'd better take it off...
Old Apr 16, 2009 | 10:30 PM
Car: 1987 GTA
Transmission: 4L60e
If it's that much - maybe I ought to add more! Have you seen my wheel gap?
Old Apr 16, 2009 | 10:59 PM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Like others have said, go ahead and add as many ground straps as you want. The more the better.
On my 87, I didnt have a strap from the back of the head to the firewall. I had wierd voltage surging and my lights would dim under WOT... On my 86 I added a strap back there, and put on new straps everywhere else. I have one from behind the alt over to the chassis rail. Now I have great charging, no surging, and no light dimming.
I got my straps from advance auto..in the help section. They're pretty nice straps for a few bucks.
J.
Frozer!!!
Jan 19, 2024 04:55 PM
Cleotiz
Aug 23, 2015 12:07 PM
redmaroz
Aug 16, 2015 11:40 PM
reiderz iroc
Aug 13, 2015 04:57 PM
