Mac mid lengths?
Old Jun 10, 2009 | 09:28 PM
BlueZee28's Avatar
Engine: Cammed 6.0L LSX
Mac mid lengths?
I heard from a friend of mine that supposedly Mac mid length '98-'02 headers will fit on a 3rd gen with an LSX swap. Is this true? If so, that would be an answer to prayers, as they are much less expensive than the only other obvious option, Hawks longtube swap headers. Has anyone tried to use the Macs on their swap?
Old Jun 10, 2009 | 09:47 PM
andrew69_04's Avatar
Car: 92 Camaro RS
Re: Mac mid lengths?
i've had macs on a few diff f-bodys. the headers are ok, but every set i've had they rust pretty bad, even the coated ones. I guess if they fit the third gen, it will be a nice $$$ savings over the hawks headers.
Old Jun 11, 2009 | 01:19 PM
BlueZee28's Avatar
I wouldn't mind re-coating them myself, or paying someone $100 to do it, because I'd still come out ahead of the game because they are so cheap.
Has anyone tried it?
Old Jun 11, 2009 | 02:18 PM
Shift06's Avatar
Car: 1991 Trans Am GTA
Engine: LSX (swapping)
Transmission: 4L60E (swapping)
Axle/Gears: 2.73 Posi 10 Bolt
Part number for them? I am very interested in these as well. Though I have heard the 2002 manifolds flow just as good as shorties.
Old Jun 11, 2009 | 02:56 PM
BlueZee28's Avatar
2002 manifolds don't flow as good as shorties, it's close, but not the same, and shorties don't flow as good as mids, so mids > manifolds.
Old Jun 11, 2009 | 08:05 PM
Car: 92 Camaro RS
it would be neat to see someone try. just basing off what i remember them looking like on the ls1, im thinking they will work.
Old Jun 12, 2009 | 10:28 AM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
I havent seen any threads where anyone has actually successfully installed them that I can recall.
Old Jun 12, 2009 | 03:04 PM
$750 L98's Avatar
Car: 1989 Formula 350 LSX
Engine: 5.3, 234/228 cam
Transmission: Stage II 4L60e, Vigilante 3200
It's certainly possible, just have to take the chance. Seems like alot of them won't because they flare out into places - that on a third gen, would be the "Frame". I went with edelbrock shorty LS1 headers. They were a stock replacement, so they would even connect directly to a Y pipe made for an LSX swap with manifolds.
Old Jun 12, 2009 | 03:40 PM
SheldonZ28's Avatar
Car: 89 IROC/05 RX8
Engine: LS1/LS1
Transmission: T56/T56
Axle/Gears: 3.42 GM/3.55 8.8
They Can be fit. But they wont fit without modification.
A guy i know who did the same swap as us about 4 years ago said they go into the a-arm mounts, and have to be either heated and bent inwards, or cut and re-shaped.
cowansauto
Apr 3, 2025 12:51 PM
wigmobile
Feb 26, 2025 02:56 PM
PestilenceIV
Sep 11, 2016 12:53 AM
Mongoose462ci
Sep 16, 2015 11:46 PM
Scorched1984
Sep 15, 2015 03:42 PM
