put motor mounts in wrong place..
Old Jun 24, 2009 | 02:33 PM
brianfromhawaii's Avatar
i put the spohn motor mount adapters where they go from the factory, well i didnt, a friend did, then he asked me to weld them in place... only then did i realize they are in the wrong place... ****! anyone have pics of where they really go?
Old Jun 24, 2009 | 02:40 PM
Shift06's Avatar
Car: 1991 Trans Am GTA
Engine: LSX (swapping)
Transmission: 4L60E (swapping)
Axle/Gears: 2.73 Posi 10 Bolt
Re: put motor mounts in wrong place..
There is a popup picture of them right on http://www.spohn.net
I know I almost did the same thing.
Old Jun 24, 2009 | 02:47 PM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Old Jun 24, 2009 | 03:04 PM
damn it.... i welded the crap outa it too lol
Old Jun 24, 2009 | 05:53 PM
it looks like my oil pan is gonna hit even after i move the mounts... what gives? anyone have a pic of clearance :/
Old Jun 25, 2009 | 06:16 AM
Car: 86 Trans AM
Its common...
Here's what I started with.
Here's how I dealt with it just recently.
J.
Old Jun 25, 2009 | 02:33 PM
interesting.... sounds like the tubular kmember is the way huih
Old Jun 25, 2009 | 02:59 PM
Car: 86 Trans AM
Not if you can weld and have some free time. I mean...if tubular is the way you want to go, then by all means. But if you want to use your stocker, be prepared to do alittle cuttin and welding. Especially to use the 4th gen a/c compressor.
I just wish I would have cut the notch the first go around.
J.
Old Jun 25, 2009 | 03:03 PM
well i welded the motor mounts on so im gonna assume i can weld lol.. how hard is it to take the a arms off then put them back on with that spring there??!
Old Jun 25, 2009 | 05:17 PM
Car: 86 Trans AM
Its not exactly a "hard" procedure. Just can be a bit hairy if you arent safe about it. You'll need to remove the springs.
You can get a spring compressor and try to get that to work, but Ive never found one that works well on these cars.
The method I use, can be dangerous if you dont take proper precautions and use your head. Basically, you support the a-arm with a jack so that the spring is compressed alittle. Then you remove the brake caliper and hose and hang it off to the side out of the way. Pop out the tie rod end, and remove the sway bar end links. Take off the strut retaining nut. Make sure you are supporting the a-arm at this point! Using a chain or a ratchet strap type strap, wrap around a coil of the spring and tie it to the back of the a-arm. Basic Ide is, if for some reason the spring decides to pop out, it wont get very far. Now...with the spring secured, slowly let the jack down. When the a-arm gets tilted down pretty far, the spring will just barely be hanging on the lip in the pocket. At this point, you can either give the a-arm a kick down, or using a long pry bar, pop the bottom of the spring over the lip. It might pop alittle, but there isnt much energy left at this point. Unstrap it, and remove the spring.
Install is the reversal of that.
If you go to my thread, and scroll down on page 10 you'll see some pictures of the operation.
https://www.thirdgen.org/forums/ltx-...-again-10.html
J.
Old Jun 25, 2009 | 06:24 PM
wow thanks man
Old Jun 25, 2009 | 06:50 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Could be selective or just plain poor memory, but I don't recall anyone notching for the pan before I set out to do it.
https://www.thirdgen.org/forums/ltx-...ppointing.html
Old Jun 25, 2009 | 07:02 PM
five7kid's Avatar
https://www.thirdgen.org/forums/ltx-...ointing-2.html
See posts #77 & #81.
Old Jun 25, 2009 | 08:50 PM
Car: 86 Trans AM
I remember one or two guys doing some notching....but I dont remember many pictures of it floating around. Just mentioned here and there.
I think most people have poor clearance. Even if its not touching, its still too close. 1/16" isnt acceptable to me. haha. Not with the torque these motors throw around.
Your thread was a kick in the butt to me to get my notch done haha. Speaking of your thread...I asked that guy for a picture of his contraption, and totally forgot to go back and look. Didnt realize he took pics for us.
J.
jhawkeye
May 25, 2022 06:33 PM
RazorN8
Jan 7, 2022 11:44 AM
Elliswon
Aug 10, 2015 12:33 PM
Leggman1
Aug 6, 2015 04:15 AM
NBrehm
Aug 5, 2015 07:57 PM
