5.3 Fi to carb conversion
So I have heard stories of people doing a carb conversion on the gen 3 5.3 engine. I have thought about doing this conversion myself but I was wondering if anyone has done it and whatever they can tell me about it.
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: 5.3 Fi to carb conversion
msd 6010 box
vic jr intake or performer rpm
750 double pumper or similar carb
that's about all it takes
Car: 1984 Z28
i just listed what you need to get it to run. Then buy all the ls1 swap parts from hawks or similar.
ls1tech.com has a lot of buildups as does the ls1 board on thirdgen.
On Probation
Engine: several
Transmission: none
Axle/Gears: none
if you really want a dizzy, GMPP offers a front cover that lets you run a dizzy for a Ford 351W engine.
Transmission: 4L80E/4L80E
What are you going to use the car for when this is complete?
[quote=five7kid;4297185]What are you going to use the car for when this is complete?[/quote
Street car/ road racing. I do not need a extremly high HP car but I want to be able to run higher RPM.
Car: 1987 Trans Am
Engine: LQ9/L92
What is it you're hoping to gain with the carb setup over the FI? part of the magic of these engines is the well designed injection system. Unless you're going crazy with the setup, I feel you'd probably benefit from sticking with the fuel injection system and getting it dyno tuned (or similar).
There is the possibility of going crazy, to be honest one of the biggest problems is that I HATE wiring and I really HATE having to do the dyno tuning thing, it can get really expensive and every mod you do, you have to get it dyno tuned. Lets face it, if I where at the track and in a pinch, I would be out of luck. I do agree totaly though, the FI system rocks on these motors, but I hav heard of great things from carbing these engins.
Car: 1987 Trans Am
Engine: LQ9/L92
You still have to deal with (to some extent) wiring and computer tuning when you swap to carb on these engines due to the lack of a distributor. Since I have not done that swap, I do not have all the details, but you will have to tap into a few of the stock sensors and the MSD (or relabeled GM box) still has spark curves to choose from and tweak to get everything in order.
Unfortunately not as simple as swapping from say TPI/TBI to old school carb on a SBC; electronics are still required
Car: 1984 Z28
read the instructions off msd's website for the 6010 box.
KNIGHTE
Southern California Area
Oct 22, 2015 09:11 PM
