Cheap 4" head gaskets?
Old Nov 23, 2009 | 08:22 AM
Guest
Guest
Posts: n/a
Anyone know where to get such a thing? $73 each is just not fair pricing.
Old Nov 23, 2009 | 09:13 AM
BlueIroc-Z's Avatar
Car: 1989 Camaro Iroc-Z
Engine: 305 TPI (LB9)
Axle/Gears: 2.77 posi
Re: Cheap 4" head gaskets?
EDIT: Oops... Just noticed this is in the LTx/LSx board... I just listed off a bunch of GEN I SBC gaskets,
So, what engine are you needing this for LTx or LSx? I'm not going to look through all those sites again but going of just AutoZone: Yeah, the 4" for a LSx is $60... LTx is $20... Based on that I'd bet you're after the LSx gasket...
Here's a pair on eBay for $100, might not be the right type though (MLS)?
That reminded me why I wanted to leave the heads on my 6.0L and just forego that part of the inspection, well that and the TTY bolts...
EDIT #2: Hey it looks like GMPartsDirect.com might have them for $30 each. Got part number for "6.0L Head Gasket" from here, and copy/pasted it to GMPartsDirect search. Definitely verify that PN before you buy... Possibly even contact your local dealer and see what kind of price they might have on it.
Old Nov 23, 2009 | 10:13 AM
Guest
Guest
Posts: n/a
Thanks for taking the time. I'll check it out.
Old Nov 23, 2009 | 10:50 AM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
"cheap" and "head gasket" in combination really doesn't sound like a good plan to me......
Old Nov 23, 2009 | 12:34 PM
Venom13132's Avatar
Car: 1995 RX-7 LS1
Engine: 2000 LS1
Transmission: t56
Axle/Gears: 410 limited slip
I ordered a set from Summitracing.com they are the gm performance parts. Good quality good price.
Old Nov 23, 2009 | 12:42 PM
Guest
Guest
Posts: n/a
GM's own composite 350 head gaskets, the $18 each kind, have held over 550 HP, and the early LS1s came with the same style of gasket, so why would I want MLS at 4 times the price? My LQ4 is getting a compression bump, but I'm at 4500 feet, so it's like stock compression at sea level. This build will not see any nitrous or boost, so I'd be lucky to hit 500 HP. HotRod or CarCraft did an LQ4 with the GM "HOT" cam, and got 483 hp at 6000 rpm from an early LQ4. Those iron heads have the same ports and valves as the LS1 heads I'm wanting to install.
So, my dynamic cylinder pressure won't be high enough to need MLS. Now, I've found composite gaskets for 3.9" bores, but that won't work on my block.
Old Nov 23, 2009 | 12:47 PM
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
mls = multi layer steel thats what it comes with from the factory.
Old Nov 23, 2009 | 01:27 PM
Venom13132's Avatar
Car: 1995 RX-7 LS1
Engine: 2000 LS1
Transmission: t56
98-2000 (possibly 01 also) LS1 engines came with composite head gaskets from the factory. I know cause I had to scrape it off my block/heads. I got the GM Performance MLS gaskets to replace them though.
Old Nov 23, 2009 | 03:36 PM
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
ah didnt know there was a changeover. I have an 02 Z28 and then my 03 LQ9 for my 88 they both had MLS i thought that was the norm.
Old Nov 23, 2009 | 03:46 PM
SheldonZ28's Avatar
Car: 89 IROC/05 RX8
Engine: LS1/LS1
Transmission: T56/T56
Axle/Gears: 3.42 GM/3.55 8.8
97-00 LS1's were a graphite gasket, all 01+ Gen3 motors were MLS gaskets.
As for wanting a composite gasket for a 6.0L, its not gonna happen. Almost all aftermarket companies do MLS, and if they offer a composite, only the LS1's had a composite so its gonna be a 3.910 bore.
I know its more money still, but Trick flow offers a .041" gasket, thats nice & thin, and retains the MLS holding power, and not to mention should you ever have the head off again, the MLS doesnt leave a nasty mess on the block (Trust me, ive done h/c swaps on a few different vette's/f-bodies that had original graphite gaskets, and its a bitch to clean up!)
Old Nov 23, 2009 | 05:21 PM
Guest
Guest
Posts: n/a
"autozone has .042 Mr Gasket that I used for less than $27.99 each. They are right and left specific: 5714G and 5713G."
Found on LS1Tech.com
Old Nov 23, 2009 | 05:26 PM
Guest
Guest
Posts: n/a
BTW, that 483 HP at sea level, that's maybe 401 HP at my elevation. GM says the pistons are supposed to be 0.008" out of the cylinders at top dead center, so an 0.042" gasket is really pushing my luck with stock rpm, let alone reaching for 6500 rpm. Ive seen piston-to-head collision with 0.031" clearance and 6500 rpm, using all good forged aftermarket parts.
Old Nov 23, 2009 | 05:40 PM
SheldonZ28's Avatar
Car: 89 IROC/05 RX8
Engine: LS1/LS1
Yes, the LS1 is positive deck motor, and yep the positive displacement is 0.008-0.010" depending on model/piston.
Aftermarket forged components, even factory compnents will not compress/stretch .020". Its simply not going to happen unless you've spun a bearing absolutly horribly, or a rod/piston is broken. The metal is physically incapable of that kind of movement. Its much too hard. If it had that much movement it would break.
Your stock components cannot move that much either. Running a .041" gasket is PLENTY of clearance.
A .041" gasket can boost compression a bit, but it also requires you check your valve lash cause the pushrods are basically acting like their a bit longer.
The biggest thing with a positive displacement motor, is the fact that they generally will run a gasket a bit larger then the bore. a stock gasket is about .060" larger then the bore. I actually run a 4.120 gasket on my 4.002 bore. Stock gasket is a 4.060 on a 6.0L and on a 6.2L its 4.120.
Actually on a further note, the 6.0L replacement gasket is 4.120", as their the same as the 6.2L gasket. Stock i beleive is .056" thickness. I know ZR1 9 layer MLS is .080
Anyways, this is unrelated lol. Id seriously just buy some stock MLS gaskets. Ive seen them on LS1tech for $40/pr
Old Nov 24, 2009 | 01:53 PM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
I ran some felpro graphites that I bought at sdparts with head bolts and the whole kit was 60 bucks or about that. A few years back but it was what everyone was using then. Might be worth checking into
Another time I ordered one felpro from Katech and guess what it was? 4" bore so i returned it but I figured I'd mention it as they definitely make a 4" composite. It wasnt nec cheap from Katech but I needed it fast
Old Nov 28, 2009 | 10:20 AM
Guest
Guest
Posts: n/a
TFS provided this part number: 12558936. It's the GM graphite head gasket for pre-'02 LQ4. The current price? $21.85 from www.gmpartsdirect.com and if you want MLS, the LS2 gasket is 12589227, for $29.19
So now I'm $100 ahead of buying Cometics.
Old Nov 28, 2009 | 10:21 AM
Guest
Guest
Posts: n/a
oops
Old Nov 28, 2009 | 11:43 AM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
there are specific 6.0 and 6.2L gaskets.
i have measured a 6.2 gasket at 4.092-.094. the set i have anyway.
ive seen some of them at 4.100, but none at 4.120
thickness is closer to .054.
your block and head needs to be surfaced correctly to use the trick flow gaskets.
stick with a stock GM MLS and be done with it.
Old Nov 28, 2009 | 01:06 PM
Guest
Guest
Posts: n/a
you don't read very well. Those aren't TFS gaskets, those are GM gaskets that TFS was so kind as to give me the GM part numbers for. Notice that they come from GMPartsDirect.com.
Old Nov 28, 2009 | 04:03 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
read your post about TFS/GM.
i think you should read your own thread before you tell me i cant read.
maybe i should have quoted him in my post? more or less giving you advice and trying to put out some factual numbers for you.
good luck.
3rd gen money
Sep 8, 2015 11:40 PM
355tpipickup
Aug 27, 2015 08:13 AM
NinjaNife
Aug 23, 2015 11:49 AM
qz6lwp
Aug 20, 2015 08:10 PM
