Torque to Yield Bolts
Old Oct 14, 2010 | 11:10 AM
terahertz's Avatar
Car: Camaro
Engine: 6.0 LS
Hi Everyone,
Simple question.. Are there any other torque-to-yield bolts on the LSX factory engine besides the cylinder head bolts? ie main bolts, etc?
Thanks in advance
Old Oct 14, 2010 | 12:26 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Re: Torque to Yield Bolts
Naw just the heads and mains.
Old Oct 14, 2010 | 01:11 PM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
Balancer bolt
Old Oct 14, 2010 | 02:46 PM
terahertz's Avatar
Car: Camaro
Engine: 6.0 LS
Thanks for the responses, I wasn't sure about the main bolts. I suppose I will have to order a new set.
Old Oct 14, 2010 | 02:59 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Go ARP and dont look back, dealing with a BRAND new TTY bolt breaking off in the block of a 6.0 project when we were bolting the heads down. I re use the stock balancer bolts.
Old Oct 14, 2010 | 03:48 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Main bolts are torque to angle, not torque to yield. They can be reused.
However, they are said to only be able to be torqued 3-4 times before they can't be reused, so my plan is to use the original ones for pre-assembly and do final assembly with a new stock set. Unlike the head bolts, I really don't ever see myself yanking these back off again, so I don't see the need to spend the extra on the ARPs. For the head bolts though, the ARPs are the way to go unless you're delusional enough to think your heads will never come back off.
Old Oct 14, 2010 | 04:38 PM
west1nm's Avatar
Car: 91 Z28 Vert
Engine: LS3
Conn Rod bolts too. Don't skimp on these!
Old Oct 14, 2010 | 06:46 PM
terahertz's Avatar
Car: Camaro
Engine: 6.0 LS
See.. this is why I asked this question on TGO rather than a LSx specific site. I get straight answers. Thanks everyone!
Old Oct 14, 2010 | 07:29 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
If you arent going well over 7000, the stockers hold up for everyone i know. My 6.0 sees 7100 all the time, tons of abuse, but they are cheap insurance if you just want the piece of mine.
Old Oct 14, 2010 | 09:45 PM
west1nm's Avatar
Car: 91 Z28 Vert
Engine: LS3
I would not gamble with the stock bolts. I've seen my share of genIII / genIV conn rods exit the side of the block on dyno due to rod bolt fatigue... I would go with ARP's and be sure that there is no "cap shift" of the cracked rods when tightening down.
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
billybob6110
Sep 23, 2015 01:30 PM
angel2794
Sep 8, 2015 06:22 PM
Jlanz55
Sep 6, 2015 07:28 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
