Oil pressure gauge?
Old Dec 12, 2010 | 03:12 PM
86White_T/A305's Avatar
Car: 1987 TransAm Ttop
Engine: 2005 LQ4
Transmission: Ls1 T56
Axle/Gears: 3:54
Oil pressure gauge?
So Im in the mist of prepping my harness and I pretty much have everything figured out but what I havent seen posted on here is what you guys have done for the oild pressure gauge.I want to retain my factory oil pressure gauge.Do I need a seperate sender or reuse the stock sender and tap into an oil port somewhere or can I simply wire the gauge somewhere on the ls1 harness.
I dont like having non functional gauges on my dash lol..call me crazy but its a petpeeve when I drive and see a dead guage.
Hopefully Pocket can answer this for me
Old Dec 12, 2010 | 03:34 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: Oil pressure gauge?
Can you just use a T-fitting on the LS1? Then you could use the LS1-specific sensor for its PCM, and the 3rdgen sensor for your guage.
Old Dec 12, 2010 | 03:39 PM
Engine: 2005 LQ4
Axle/Gears: 3:54
I would assume so..but Id like to hear what others have done or if thats the only way to make it work.
Old Dec 12, 2010 | 04:51 PM
Pocket's Avatar
Car: 91 Trans Am
Use the stock LS1 sender behind the intake. 87 should have the old style connector in the harness which doesnt work. Just cut the old connector off and solder the one from the LS1 harness
Old Dec 12, 2010 | 05:43 PM
Engine: 2005 LQ4
Axle/Gears: 3:54
Pocket the problem with that is my car was originally a 305carb..then converted to a 350tpi and my oil pressure guage is a single wire that had a female blade terminal on it.Will it still work..and wouldnt it cause the ecm to read incorrectly if I splice into the wire on the ls1 harness?
Old Dec 12, 2010 | 05:44 PM
one92rs's Avatar
Car: SOLD!!!!!
so the ls1 sender will work with the factory gauge or is there something else that needs to be done.
Old Dec 12, 2010 | 06:05 PM
Engine: 2005 LQ4
Axle/Gears: 3:54
thats what I want to make sure of lol
Old Dec 12, 2010 | 06:46 PM
Pocket's Avatar
Car: 91 Trans Am
Cut the blade off the wire. Locate the oil connector in the LS1 harness (one wire). Cut it off and solder it onto the 3rd gen wire that used to have the blade
The LS1 sender will drive the 3rd gen gauge no problem
Old Dec 12, 2010 | 07:19 PM
Engine: 2005 LQ4
Axle/Gears: 3:54
Awesome.Thanks Pocket..you are the man .All of your posts have come in handy to the T lol.
Old Dec 14, 2010 | 08:48 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
exactly what i'm doing myself. stock ls1 sender for the oil and a 98 3-wire temp sender/switch for the coolant
89GTAOz
May 16, 2020 09:31 AM
355sbcTPI
Aug 19, 2015 04:38 PM
bamaboy0323
Aug 15, 2015 07:20 AM
ChevyZ71
Aug 13, 2015 07:30 AM
