anyone get truck brackets to work?
Old Jan 18, 2011 | 09:04 PM
pajama sam's Avatar
Im on a really tight time frame and i need to get my truck brackets to work with the alternator. If i have to ill make my own mount for where the ac was. But i saw in the truck in thirdgen thread that it was said that some people modify the bracket to make it work. Anyone know how or whats my option.
Im running a carb setup. so waterneck problem wont be a problem
Old Jan 18, 2011 | 10:29 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Re: anyone get truck brackets to work?
Going to make mine work for me, will post pics of progress when everything is going in but i do have a cowl hood on my TA.
Old Mar 15, 2011 | 09:25 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Old Mar 15, 2011 | 11:31 PM
Thridgen60's Avatar
Car: 86 Camaro
Engine: 6.0L LQ4
Transmission: 4L80E
Axle/Gears: 9 inch, 3.50
Some people cut the top half of the alt/power steering bracket off only using the lower half for the power steering. Then make a bracket for the alternator above it that mounts lower so it will clear the hood.
Old Mar 16, 2011 | 02:54 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Mine is actually the stock 87-92 f body alternator in the ls truck bracket, it is a smaller alternator.
Old Mar 16, 2011 | 05:50 AM
Demon355's Avatar
So all this fit under a stock hood by chance? What did you do to the bracket? What belt to use? Work with stock LS1 water pump?
Old Mar 16, 2011 | 12:33 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
I have a daytona turbo hood, it is about a 2 inch cowl, but it looks reallt close to fitting with a stock hood, it will clear a formula firebird hood for sure. I just knocked out the metal piece in the bracket on the left side and used 2 washers to space it out right and bolted it in.
Old Mar 18, 2011 | 04:28 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
that setup will work if you're not using the typical intake/tb setup, but the idler pulley is in the way if you are.
Terrell351
Jun 13, 2021 01:13 PM
Wylecoyote08
Nov 6, 2015 03:46 PM
rh76camaro
Aug 15, 2015 12:48 PM
jahblah
Aug 12, 2015 05:54 PM
squiggy2
Aug 9, 2015 09:30 PM
