lq4 no start
Old Feb 4, 2011 | 06:34 PM
pajama sam's Avatar
lq4 no start
So i just got everything hooked up on my lq4 and it cranks over and is getting fuel but not getting spark. I have the edelbrock intake and edelbrock ls swap box thing. What are some things i can test, i have no idea why its not getting spark.
Main power and ground are good(tested those)
Thanks in advance.
update: Did some more testing. i was only getting 4v to the box when cranking.
Im going to charge the battery and see what happens. Any other ideas?
Old Feb 4, 2011 | 06:38 PM
White'89's Avatar
Car: '89 GTA
Engine: 5.7L LS1
Axle/Gears: 9 bolt 3.27
Re: lq4 no start
If the starter is strong there is nothing wrong with your battery. I assume you have the ignition box tapped into the 3rd gen main IGN wire?
Old Feb 4, 2011 | 07:45 PM
pajama sam's Avatar
Re: lq4 no start
No i just found a keyed hot wire. whats the main ign wire? the one going to the purple one going to the starter?
Old Feb 4, 2011 | 08:00 PM
White'89's Avatar
Car: '89 GTA
Engine: 5.7L LS1
Re: lq4 no start
The main IGN wire is a large pink wire coming out of the C100(large bulkhead connector on driver side firewall. I would try using that as your Ignition power.
https://www.thirdgen.org/forums/ltx-...formation.html
https://www.thirdgen.org/forums/ltx-...rt-finish.html
Pocket's got ya covered
Old Feb 4, 2011 | 08:22 PM
pajama sam's Avatar
Re: lq4 no start
Alright ill try switching it to that tmo.
Anyone else got ideas if this doesntwork?
Old Feb 4, 2011 | 09:38 PM
kevinc's Avatar
Car: 1982 Z28
Re: lq4 no start
People sometimes tap into Accessory circuits for their fuel/spark/PCM power which leads to this problem...improper voltage during cranking.
Old Feb 4, 2011 | 09:42 PM
White'89's Avatar
Car: '89 GTA
Engine: 5.7L LS1
Re: lq4 no start
Oh and in case you haven't seen it already this thread will probably be a bit more informative.
https://www.thirdgen.org/forums/ltx-...p-3rd-gen.html
Old Feb 5, 2011 | 03:55 PM
pajama sam's Avatar
Re: lq4 no start
The wiring did it. I moved the pink wire to the main ign of the car and it fired right up! awesome thanks a ton guys.
SiCkRs
Members Camaros
32
Jul 1, 2018 04:53 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
86White_T/A305
Aug 17, 2015 12:16 AM
92camaroJoe
Aug 13, 2015 06:07 AM
