Truck 5.3 in 89 Iroc
Old Mar 7, 2011 | 05:14 PM
scooted45's Avatar
Car: 86 sport coupe, 89 IROC-Z
Engine: 5.7 TPI, 5.0 TPI
Transmission: T-5, T-5
Axle/Gears: drum posi 3.73, disc open 2.73
I have a line on a 0 mile truck 5.3 drivetrain and id like to use as many of the truck parts as possible. Its a 5.3 with a 2wd 4l60e accessories and harness/ pcm.
Ive got a 180k iroc begging for an LS swap
Can I find a pump/ regulator that would work with the stock tank?
Will the 4l60e will bolt in?
I read all the stickys. Theyre pretty good and explaining the swap to some one with a big buget or donor car, not too much about the more abundant truck setups.
Old Mar 7, 2011 | 05:19 PM
White'89's Avatar
Car: '89 GTA
Engine: 5.7L LS1
Axle/Gears: 9 bolt 3.27
Re: Truck 5.3 in 89 Iroc
https://www.thirdgen.org/forums/ltx-...otor-into.html
Read.
Old Mar 7, 2011 | 05:22 PM
scooted45's Avatar
Old Mar 7, 2011 | 05:28 PM
scooted45's Avatar
didnt see anything in there about either question
can a drop in pump power an LS with a regulator,
and does a 4l60e bolt in?
Old Mar 7, 2011 | 05:41 PM
White'89's Avatar
Car: '89 GTA
Engine: 5.7L LS1
http://www.ls1tech.com/forums/conver...or-filter.html
Also in the sticky. Since it looks like you have TPI cars all you have to do is buy a Walbro 255 and put it on the stock sender, and add the corvette regulator.
Old Mar 7, 2011 | 05:45 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
What do you mean by "drop in pump power"?
I used a Walbro 255 pump in a 3rd gen EFI pick-up unit, and a Vette LS1 filter with built-in return and pressure regulation. Fuel line adaptation required.
An LS1 4L60E will bolt up to a 5.3l. It will not "bolt in" to the car, because the tranny mount is in a different place vs. the 3rd gen TH700R-4. You can either modify the stock crossmember, or get a $110 piece from Hawks that will bolt in. The good news is the stock shifter will work with the 4L60E.
Old Mar 7, 2011 | 05:49 PM
White'89's Avatar
Car: '89 GTA
Engine: 5.7L LS1
http://www.hawksthirdgenparts.com/ls...sionparts.aspx
Old Mar 7, 2011 | 06:26 PM
scooted45's Avatar
Cool, good info, thanks again. Is it feasable to use the factory 700r4 tailshaft? Then I could run a later 88+ speedo electric setup and mount the torque arm too.
Old Mar 7, 2011 | 06:29 PM
scooted45's Avatar
Sorry, i meant will a different pump on a stock sender be able to supply the needs of an LS.
Old Mar 7, 2011 | 07:27 PM
Willie B.'s Avatar
Car: 91camaro
Engine: 5.3
If you have a ram air or cowl induction hood 3"-4". you can use the truck front end accessories and the intake. Thats what i decided to use on my swap just to have a different look when i pop the hood. Vortec
Old Mar 7, 2011 | 07:45 PM
Pocket's Avatar
Car: 91 Trans Am
700R4/4L60's use a 4 bolt tail housing flange. LS style 4L60E's use a 6 bolt flange. There is an adapter available but its more than the cost of the correct tailhousing
Grab one from a 98+ V6 Fbody which litters the junkyards
Old Mar 8, 2011 | 08:56 AM
scooted45's Avatar
Oh ok, Ive rebuilt a few truck 4l60Es but never an ls style 2wd. Ive never even seen one for a 4th gen.
Dang, just sold my 4" cowl hood. It was a perfect blind spot tho.
Also, does a fly-by-wire with a pedal sound feasable? This truck setup truly has everything. Complete harness, acessories, trans.
Old Mar 8, 2011 | 09:13 AM
Pocket's Avatar
Car: 91 Trans Am
DBW will work once you fit the pedal in there and run the TAC module
Old Mar 8, 2011 | 01:34 PM
scooted45's Avatar
I know alot of guys try to eliminate the fbw throttle body, didnt know if theres was a reason other than not having all the proprietary doodads.
I would like to document the swap this summer, for now im trying to see how expensive it will get. Im hoping to stay under $1500 after buying the engine. If its obviously going to be WAY more than that, Im probly going to stop dreaming.
Old Mar 8, 2011 | 02:17 PM
scooted45's Avatar
Im going to hope fully take some pics today when I see the engine/trans. Maybe then I can make a better decision.
nuggie
Aug 25, 2015 01:27 PM
hayesaw0210
Aug 23, 2015 11:15 PM
jharrison5
Aug 19, 2015 05:53 PM
mustangman65_79
Aug 11, 2015 03:17 PM
