Finally made up a CAI !
Old Jul 7, 2011 | 09:58 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Installed it this afternoon after a trip to Summit Racing. Spectra 4* 90 Elbow, Spectra straight tubing, K&N Union, Spectra 45* tubing and a Summit Filter. (Summit filter came in a K&N box with K&N sticker lol.) Running SD so no MAF.
Old Jul 8, 2011 | 09:10 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Re: Finally made up a CAI !
It isnt a CAI if it is drawing hot air from the engine comartment. Nice to know about the air filter though, which part number did you get?
Old Jul 18, 2011 | 11:15 PM
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
put it through the battery tray and put the filter right behind the fog light thats what i did
Old Jul 18, 2011 | 11:31 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The air over in the corner is cooler than other parts of the engine compartment. I'd say it qualifies.
Old Jul 19, 2011 | 09:17 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
If that helps you sleep at night.....
I am surprised no one has thought to just make a "wall" that seals to the hood to make something like the OP did more cold air, like a lot of the aftermarket comanies are doing.
Old Jul 19, 2011 | 10:34 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
So far so good. I ended up throwing in a 5 pin MAF also. Not hooked up yet but we'll see. I wired it in the harness so I could use it if I wanted too. It goes to the dyno next week hopefully. I'll see what happens.
Old Jul 19, 2011 | 10:51 AM
1nasty86's Avatar
Car: 1986 camaro
Engine: ls2
Transmission: FLT stage 6 60e
Axle/Gears: 8.8 with 3.73's
If the cai is made of aluminum you may have heat soak issues... I have the problwm with my cold air and im switching to hard plastic
Old Jul 19, 2011 | 01:10 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Yes. aluminum tubing.
Old Jul 19, 2011 | 01:59 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Mine is made of 4" aluminum tubing but I had the interior coated with a ceramic thermal barrier and the outside with a heat dispersent. That is an added cost but works. Plastic would be the cheaper way to go.
By the way going down the freeway at freeway speed my IAT was running 77F with the probe in the factory location in the plenum. So it does work.
Old Jul 19, 2011 | 04:43 PM
five7kid's Avatar
Compared to a filter above the radiator, yes.
Some have.
Old Jul 19, 2011 | 04:44 PM
five7kid's Avatar
I wrapped mine with heat reflecting tape.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
morrow
Jan 13, 2024 12:29 PM
tglennon11
Interior Parts Wanted
Sep 11, 2015 10:25 PM
dimented24x7
Sep 6, 2015 03:51 PM
