first test drive after ls longtubes
Old Sep 4, 2011 | 09:33 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
I had a pretty bad rasp with the manifolds and after seeing countless longtube installs on ls1tech ending with unbearable rasp I was planning for the worst. well Im surprised and glade its gone guess my merge I made worked very well
Old Sep 5, 2011 | 07:51 AM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Re: first test drive after ls longtubes
So what is your whole set up now? I have LT's, a custom merge, and magnaflow. The ypipe flows about as smooth as you can get, and the merge is a flowmaster 2.5-3. So it should be pretty decent too. But I still get more rasp than I like. Was thinking about fighting it with some high flow cats someday.
J.
Old Sep 5, 2011 | 08:59 AM
Jaysz28's Avatar
Car: 91 Firebird
Engine: 6.0
why not use a short bullet muffler in the I-pipe?
Old Sep 5, 2011 | 03:00 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
No raspiness with either of mine.
Old Sep 5, 2011 | 05:28 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Manifolds...i have a pile of those, never used them. Rasp wise, my RS has 1 chambers, so you can imagine it is load, but it is deep, but the 86 TA with the 3 inch into a 3 inch Y with shortys has the bullet muffler and only really has raspieness at a given rpm slightly accelerating:
http://www.youtube.com/watch?v=QrMMhDP1EJY
Old Sep 5, 2011 | 06:10 PM
Engine: ls1, LB9
its the hawks knock off long tubes and then its 3" SS mandrel bends to make up my y-pipe and I made my own merge and then the rest is the old slp catback 2 on the left
the only real difference is I went from the cast manifolds and changed the way I had the two pipes merge.
Old Sep 5, 2011 | 09:41 PM
White'89's Avatar
Car: '89 GTA
Engine: 5.7L LS1
Axle/Gears: 9 bolt 3.27
Define rasp?
I dig the sound my car has with the manifolds, 2 1/2" Ypipe, flowmaster merge into SLP 2OTL catback.
Old Sep 6, 2011 | 08:52 PM
Engine: ls1, LB9
Originally Posted by White'89
Define rasp?
http://s70.photobucket.com/albums/i9...t=MOV03321.mp4
http://ls1tech.com/forums/generation...vids-pics.html
1984HO
Mar 19, 2021 11:59 AM
Street Lethal
Apr 30, 2019 12:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Dialed_In
Aug 20, 2015 01:45 PM
