91 Z/28 6.0L/T56, Husler Mid-Length Headers
Old Oct 3, 2011 | 10:34 AM
STREETDEMON's Avatar
Car: 91 Z28
Engine: 6.0L LQ9
Axle/Gears: Dana 44 3.92
91 Z/28 6.0L/T56, Husler Mid-Length Headers(BRP), 8.8 Hybrid
started my swap last month, i have a thread going on ls1tech as well.
here is what i started with. 103K all original G92 Z/28, L98/700R4.
Old Oct 3, 2011 | 10:36 AM
Car: 91 Z28
Engine: 6.0L LQ9
Re: 91 Z/28 6.0L/T56
picked up a 55k LQ9 block and a 13K T56.
Old Oct 3, 2011 | 10:38 AM
Car: 91 Z28
Engine: 6.0L LQ9
started the disassembly and unwiring process.
pulled the old engine and tranny out together by myself. wasn't as bad as everyone plays it out to be, i did this without my leveler as well. just get the rear end high and leave the front end on the ground.
Old Oct 3, 2011 | 10:41 AM
Car: 91 Z28
Engine: 6.0L LQ9
notched the k-member and removed the engine mounts. all you need a set of long handled wrenches and an impact gun on top, and this also becomes an easy task.
Old Oct 3, 2011 | 10:45 AM
Car: 91 Z28
Engine: 6.0L LQ9
cleaned the engine bay, intalled the poly bushings in my engine mounts, made nut plates to install the new engine mounts, and boxed the k-member back in.
i absolutely cannot weld upside down over my head...no matter how much i practice. but what i burned on will work, and after the grinder it will look just fine. the top came out the best.
Old Oct 3, 2011 | 10:51 AM
Car: 91 Z28
Engine: 6.0L LQ9
now time to por-15 the k-member, hang the new pedals, make the hole for the tick master cylinder, cut a hole for my pocket wire harness, and start on the cam swap in the engine.
cam choice has been very difficult. there are too many choices out there. i've considered:
Futral F13 112+4
Thunder Racing TruTorq LVL 4
TSP Torquer V3
Ed Curtis Streetsweeper HT
and Geoff at EPS spec'd me one like 1nasty86, 230/238 on a 113
i think i have decided on the F13, it is tried and true, and puts up great numbers.
the engine will get a set of long tubes (hopefully the new BMR's we've been hearing about), and an LS6 intake.
Old Oct 3, 2011 | 11:36 AM
1nasty86's Avatar
Car: 1986 camaro
Engine: ls2
Transmission: FLT stage 6 60e
Axle/Gears: 8.8 with 3.73's
go with the eps! i love mine, made 463 with it 95* in the shop. ported 317's, fast 102 and that cam.
Old Oct 3, 2011 | 11:40 AM
Car: 91 Z28
Engine: 6.0L LQ9
nasty it's a tough decision, i know i can make north of 400 with both hp and tq with the Futral cam(with a good tuner). i don't have all the good intake stuff up top like you have, not sure if the eps cam will do what i'm looking for with just an LS6 intake and headers.
Old Oct 3, 2011 | 11:47 AM
1nasty86's Avatar
Car: 1986 camaro
Engine: ls2
thats fully up to you.. whipple is discussing making a 2.9 for the f body so my stuff may be for sale here shortly lol
Old Oct 3, 2011 | 11:52 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I'm north of 400 with alot smaller cam and LS6 intake. And I'm running an automatic. Running a TF / TEA 228/230 585/585 112 Cam
Old Oct 3, 2011 | 11:59 AM
Car: 91 Z28
Engine: 6.0L LQ9
mkos, the Street Sweeper HT is made by the same company i believe, its 228/232.
Last edited by STREETDEMON; Oct 3, 2011 at 12:15 PM. Reason: found his post with the info i needed....
Old Oct 4, 2011 | 11:04 AM
Car: 91 Z28
Engine: 6.0L LQ9
the ups santa clause showed up today....
my new Monster Stage 3 Premium clutch kit.
can't wait to start bangin' some gears.....
Old Oct 4, 2011 | 11:56 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Originally Posted by STREETDEMON
What engine mounts are you going with?
Old Oct 4, 2011 | 12:09 PM
Car: 91 Z28
Engine: 6.0L LQ9
stock style gen 1 clamshells and engine mount plates....i'm also going to run a high mount AC compressor in the stock location.
these bolt to the lsx engine, and engine side of the gen 1 clamshells bolt onto the plate.
Old Oct 4, 2011 | 09:37 PM
daddy33's Avatar
Car: '85 Camaro
Your swap is looking pretty good! You'll have fun hanging those pedals lol. If you need any help guiding through, let us know. I'm sure lots of us have tons of info to help
Keep up the good work!
Old Oct 5, 2011 | 11:32 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
I was thinking about doing that, how thick are your plates?
Old Oct 5, 2011 | 07:18 PM
Car: 91 Z28
Engine: 6.0L LQ9
3/8"
Old Oct 10, 2011 | 09:17 AM
Car: 91 Z28
Engine: 6.0L LQ9
pulled the trigger on the F13 cam last week.
waiting on my coils and brackets(at the post office....but of course its closed), need to get the axle and tank dropped out from the car to put the fuel pump in.....
getting down to the point where i have to do all the little stuff that i don't want to do!
Old Oct 10, 2011 | 12:51 PM
HP52TA's Avatar
Car: 89 WS6 TransAm
Engine: LQ408
Transmission: T56 Magnum
Axle/Gears: Strange S60, 4.10s
That is a real nice base for your build. Car looks to be in great shape.
When the little stuff starts to get to you .. and it will, take a break, just not as long as mine are sometimes ...
I find the wiring has been my biggest struggle.
Old Oct 12, 2011 | 10:14 AM
Car: 91 Z28
Engine: 6.0L LQ9
some more goodies in the mail. heat sink coils and a spare set of valve covers that were included in the price. i hope to get some painting done this weekend on some the components; valve covers, coils/brackets, intake, fuel rails. also going to try and drop the axle and tank...which i think is full of fuel
Old Oct 12, 2011 | 10:15 AM
Car: 91 Z28
Engine: 6.0L LQ9
i've got a hurst billet plus shifter coming and got my pump and udpated harness ordered from racetronix.
need to get my fuel injectors and computer sent out soon....
i think i have decided to try and find LS2 GTO accessories since i'm not having much luck with the fbody stuff.
Old Oct 12, 2011 | 11:15 AM
jamieschott's Avatar
Nice build so far. Sure is getting me pumped up to continue with mine once I get back to the house after 8 long weeks of training!
Old Oct 12, 2011 | 12:10 PM
Screamin86's Avatar
Car: 86 Trans Am,03 Yukon,92 Z28
Engine: 5.3, 5.3, lb9
Transmission: th350,4l60e,700r4
Axle/Gears: 3.73,3.73,2.73
looks great! i need to get out there and finish my swap lol.
Old Oct 14, 2011 | 03:29 PM
Car: 91 Z28
Engine: 6.0L LQ9
more awesome today from the usps and ups...
Hurst Billet Plus, picked up new for less than half of retail.
and a 5-wire 85mm maf from a gm pickup.
Old Oct 17, 2011 | 09:12 AM
Car: 91 Z28
Engine: 6.0L LQ9
didn't get as much done this weekend as i wanted....ended up working on racecars all day sunday. we've got new sbf strokers in 2 of the cars. one isn't running quite right, and, of course, its the one in my wifes car....
we did get the intake, valve covers, and coil packs painted. i made a template for the clutch master cylinder, and did some prep work underneath the car to drop all the tail end out of it.
Old Oct 17, 2011 | 09:18 AM
musclecar70sfan's Avatar
Car: 91 Trans Am 'vert
Engine: LB9
Axle/Gears: 3.45 9 bolt
No big deal, if your fuel pump is still functioning then just stick the main fuel line into any container and jump the relay and it'll do the work for you.
Nice project though, keep up the good work! That is an interesting color combo you've got going on the engine, should look good with the white exterior/red interior!
Old Oct 17, 2011 | 01:15 PM
Car: 91 Z28
Engine: 6.0L LQ9
musclecar70sfan....not a bad idea, no problems with the pump, so it should work.
two more boxes today....
one from Superior Chevrolet - F-body oil pan, windage tray, dipstick, LS7 lifters, timing chain, high volume oil pump, throttle cable, LS6 valley cover, etc.
and the other from Racetronix - new GSS340 pump kit with hotwire setup...also has the 15hp sticker mod(seen on top of everything in the box)
Old Oct 17, 2011 | 05:27 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
I'd invest in some cheap LS2 lifter guides too.
Old Oct 18, 2011 | 11:26 AM
Car: 91 Z28
Engine: 6.0L LQ9
yeah, i'll have to look into the guide plates, we'll see when i get down to my others.
i received my shifter plate and the much anticipated Pocket harness. hands down, great quality, Jon does great work!
Old Oct 18, 2011 | 12:53 PM
Screamin86's Avatar
looks great! agree Jons work is top notch my harness was done very well also!
Old Oct 21, 2011 | 03:32 PM
Car: 91 Z28
Engine: 6.0L LQ9
well...the bumpstick is in...time to get some stuff done. i've reserved the weekend for strictly wrenching!
also came across a sweet deal on an ls1 fbody f.e.a.d. with a 25% powerbond underdrive pully. so no more worrying about that.
Old Oct 24, 2011 | 09:06 AM
Car: 91 Z28
Engine: 6.0L LQ9
well, we got quite a bit done this weekend. the wife helped me out on saturday. we got the pedals and tick MC installed. i hope i never have to change that MC, i may just sell the car.....
i also installed my ls1 throttle cable, with the bluezee washer mod...thanks nick!
she got the battery tray and k-member painted while i was drilling holes in the wrong place.
sunday i got the axle and tank dropped. put the new fuel pump in and started working on the engine. i got it disassembled and installed the cam, oil pump, timing chain, and new pan. worried about the oil pump bolt....i torqued it to spec, but i think it was too much.
Old Oct 24, 2011 | 10:06 AM
MI ROC-Z's Avatar
Car: 89 IROC-Z
Engine: L98 5.7 liter
Transmission: TH700r4
Axle/Gears: limited slip 3.23
Looking good! Subscribed, can't wait to see the finished product.
Old Oct 29, 2011 | 06:53 PM
Car: 91 Z28
Engine: 6.0L LQ9
guys, getting ready to drill my hole for the harness under the hvac box....
did anyone get into any plastic on the engine bay side or interior side? i'm very leary about where to drill the 2" hole...can't seem to find a good spot than i'm "comfortable" with.
and pictures or guidance would be appreciated. i searched, and found what i could, but ended up with more questions.
Old Oct 29, 2011 | 07:11 PM
daddy33's Avatar
Car: '85 Camaro
kinda hard to see but you get the idea. The 2" hole is near some existing screw holes in the lower side of the firewall. It didn't get into anything inside the car, besides the furry carpet insulation. Just go at it
Old Oct 29, 2011 | 07:36 PM
porkenstein's Avatar
Car: 91 RS Convertible
Engine: LSA
Transmission: 6060
Axle/Gears: 373
subscribed as I am in the process of doing the same thing.
Old Oct 30, 2011 | 10:03 AM
HP52TA's Avatar
Car: 89 WS6 TransAm
Engine: LQ408
Just to be safe, I would pull that oil pump bolt and check it. If the bolt stretched you should be able to see it in the threads. (Compare it to a good one) With the block being iron I doubt the internal threads would be harmed.
In looking at your engine bay, one tip five7kid passed onto me was to run the brake lines inboard of the steering shaft, which really improves the room for headers, as well prevents the headers from heating up your brake fluid in the lines.
Build is coming together nicely. Looking great man!
Old Oct 31, 2011 | 08:31 AM
Car: 91 Z28
Engine: 6.0L LQ9
hp52ta....it was the bolt for the pickup tube. i pulled on the tube and worked it around, everything seemed to be good and tight. i'll probably end up pulling the pan and checking it, just frustrating when you do things "to spec" and you get that gut feeling that it wasn't right.
i'll try and get some pictures up of the progress later today. sprayed the engine bay in JD Blitz Black, and got the hole drilled for my harness.
Old Oct 31, 2011 | 10:21 AM
Car: 91 Z28
Engine: 6.0L LQ9
pics from this weekends progress...painted the engine bay and bored the hole for the computer harness.
also took my heads in this weekend to get checked over and have some Comp 918's installed.
Old Nov 3, 2011 | 07:15 PM
POP6482's Avatar
Car: 1989 Iroc-Z Convertible
Engine: 6.0 LQ4 LSX
Axle/Gears: Moser 12 bolt w/4.11s
subscribed......starting my build soon. Looks like your making progress. GL!
Old Nov 3, 2011 | 07:32 PM
Car: 91 Z28
Engine: 6.0L LQ9
more to come this weekend, sunday is set aside for kicking some tail.
ordered a pickup tube girdle from BRP this week and installed it tonight. wanted a little extra piece of mind. i feel much better about the whole situation. going back and doing the pan and front cover again wasn't what i wanted to do!
took my heads in last weekend and picked them up today, had them checked over and comp 918's installed and height checked. waiting on my new lifter buckets so i can bolt everything back up with the ARP headbolts.
Old Nov 4, 2011 | 01:09 PM
  #42
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
Awsome build man I look forward to seeing the end result
Old Nov 4, 2011 | 02:16 PM
  #43
Heritage Z's Avatar
Car: 92 Z28
Engine: L76 in the works.....
Axle/Gears: 3:73
What is the part number of the fuel pump kit you went with? I'd like to find out more info on it.
Thanks.
Old Nov 4, 2011 | 02:48 PM
  #44
Car: 91 Z28
Engine: 6.0L LQ9
6six6, thanks, i'm ready for it to be done!
heritage z, it is rfpk-005. comes with the gss340 pump, install kit, and hotwire kit. you can also add some other stuff to it as well.
Old Nov 4, 2011 | 04:04 PM
  #45
6SIX6's Avatar
Car: 89 IROC
Not a problem man. Im close to having mine done as well. Just need to get my harness back from pocket and pretty much done then. I see you went with the ractronix hotwire kit. I got the same kit when I bought a LS1 tank from my friend that had it in his car. I still have to figure out where the purple, black and grey wires would connect to or if they do. Its the tanks shock connector wiring. I know where the rest goes LOL
Old Nov 4, 2011 | 06:24 PM
  #46
Heritage Z's Avatar
Car: 92 Z28
Axle/Gears: 3:73
I appreciate the info. Along with everyone else I am also doing this same swap. I look forward to seeing the progress you make.
Thanks.
Old Nov 6, 2011 | 08:07 PM
  #47
Car: 91 Z28
Engine: 6.0L LQ9
installed the fuel tank, made most of the fuel line, just have to put the engine in to figure out the length of the line to the fuel rail.
worked on the "hotwire kit" from racetronix. need to get it zip stripped up.
got the lifters, lifter buckets, and heads installed. should have just went with the ARP stud kit. live and learn i guess.
broke a rocker bolt, but was able to get it out...and did some checking on pushrod length, still undecided if i need to go up to 7.425's.
ordered some rebuilt bosch white injectors from the supercharged buicks...flow 41.5@ 58psi.
still need to get the computer sent off for a base tune.
i'll try and get some pics up of the progress sometime this week.
Old Nov 6, 2011 | 08:15 PM
  #48
blakecharles's Avatar
Are those transdapt plates your using??
I have those same plates. The holes on the plate don't line up with the holes on the block. I've tried a few pairs and they all seem to be this way.
Is there some special way of putting them on?
Old Nov 7, 2011 | 08:13 AM
  #49
Car: 91 Z28
Engine: 6.0L LQ9
blakecharles, haven't got mine put on yet, but mine are ebay plates. from everything i've read on here they have no fitment issues.
i'll post more when i get mine mounted.
Old Nov 14, 2011 | 08:41 AM
  #50
Car: 91 Z28
Engine: 6.0L LQ9
made some good progress on the engine this weekend. installed the new trick flow 7.425" pushrods.
put in the knock sensors and finished up as much of the top end as i could, not sure on the intake yet, i may wait until after i get the engine put in.
the ebay engine mount plates required a small amount of grinding to clear one of the threaded bosses on the block. my sbc mounts also had a an area pressed out that required some grinding and then a few good whacks from a bfh. pictures below.
i'm near the end and it has given me a good boost to finish this project. just need to gather up some time!
