LSX high Rev upon first start
Old Oct 18, 2011 | 02:40 PM
88FormulaKiller's Avatar
Car: 1967 Firebird P.T.
Engine: LS3 4" Strkr 422ci
Transmission: MN12 6 speed
Axle/Gears: 3.73 8.5" 10 Bolt Eaton
Anyone have that? i know normally a cold engine is going to rev high and then idle until warm but i noticed my 5.3 revs alittle too high before settling and does it even when already warmed up? im gonna check the IAC first but i wanted to see if maybe some others had this issue...
Old Oct 18, 2011 | 04:15 PM
Pocket's Avatar
Car: 91 Trans Am
Re: LSX high Rev upon first start
Hook a scanner up and monitor the TPS value and IAC steps
Old Oct 18, 2011 | 07:15 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Whats hi? Mine revs to about 1800 for 2 seconds them idles its way to about 1000 after 10 seconds. Stays that way till warm then holds an 850 idle.
Old Oct 19, 2011 | 06:29 AM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Watch your volume on this... But here's a vid showing my tach during a colder start up. Its open headers...but its how it acts all the time.
Well....this is before my last tune. My hot idle is set a little lower now. In the vid, it was set around 900 I believe because of the alum flywheel.
http://www.youtube.com/watch?v=hd3Pr...eature=related
You can see it flares for a second or two, then settles down. It does this even when its colder outside. Might stay a LITTLE higher for a bit...but no where above 1000rpm. Might idle at like 950 for a minute before settling to 900.
You could check vac lines, check for leaky injectors, and also check what Pocket said. Is this a stock tune? Or has someone tweaked it?
J.
Old Oct 19, 2011 | 07:13 AM
Well it has a tune by Spareecm, stock ls1 tune with 26# injectors. I watched it some more last night and it did get a little better after it was warmed up and driven but i think i should get some fresh sensors, the ones i have on the TB have about 50K on them. It hits almost 2K on the tach. My speedo isnt working either for some reason. Little steps i suppose. thanks for the responses.
Old Oct 19, 2011 | 07:54 PM
1quickirocz's Avatar
Car: 88 IROCZ
Engine: 5.3 Gen IV
Transmission: 4L65E
Axle/Gears: Moser 12 bolt 4.10
I wouldnt jump to throwing a new TPS or IAC in there.....If the MAF sensor is doing anything dumb it could cause a spike in RPM but it could also be in the tune. I would look into the tune first before changing anything. Well thats after checking for vac leaks.
Old Oct 19, 2011 | 08:04 PM
Pocket's Avatar
Car: 91 Trans Am
Did you bypass the buffer box since your bird was a TBI?
Old Oct 20, 2011 | 06:07 AM
Car: 86 Trans AM
I was going to mention whether or not you are sure your TACH is set up properly. Or is it obviously revving high (using your ears).
I agree on not just tossing sensors at it. 50k isnt an indication that a sensor is bad. I have sensors on my Jetta that are 140k old with no issues. Not saying its not a sensor...but I would do some more checkin.
Ide suspect the tune at this point especially since it had some fuel tinkering done via a mail in operation.
Are you planning to have it tuned any time soon?
J.
Old Oct 20, 2011 | 07:44 AM
no i didnt
Old Oct 20, 2011 | 07:46 AM
J.
ghetto i watched your Vid, looks like mine is only a few hundred RPM's above that so maybe its not as abnormal as i suspected it. im going to mess with it more friday/sat/sun since its been raining like crazy here. thanks for all input.
Old Oct 20, 2011 | 04:19 PM
Pocket's Avatar
Car: 91 Trans Am
Find the buffer box and connect pins C and F. A short length of wire bent to a U with spade terminals will suffice
http://www.austinthirdgen.org/mkport...SS_V8_vinE.jpg
Jumping a few hundred RPM for a few seconds is normal, atleast for all of my LSx stuff, even the stock truck does it. It never breaks 2,000rpms though
Old Oct 20, 2011 | 05:47 PM
thanks jon, i dont know what the hell i would do without you. lol
Infested
May 22, 2018 11:56 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
mdtoren
Aug 23, 2015 12:52 PM
86White_T/A305
Aug 17, 2015 12:16 AM
perZ
Aug 15, 2015 01:17 PM
