LS6 - - what T56 needed?
Old Nov 23, 2011 | 12:38 AM
Copperhead's Avatar
I've recently come across a complete LS6 and a suitable 5-speed roller. The only T56's I have found so far are LT1 versions. How hard/expensive is it to convert the LT1 trans to LS6 mode? Or should I just wait for an LS1 trans?
Old Nov 23, 2011 | 04:21 AM
fast377's Avatar
Car: 91 Z28
Transmission: t-56
Axle/Gears: 3.73 4th gen 10 bolt
Re: LS6 - - what T56 needed?
Just get the LS1 T56. It's very pricey to convert the LT1 gearbox so it works. The input shaft and the mid plate need to be changed, and you just can't find them cheap.
Old Nov 23, 2011 | 07:05 AM
88FormulaKiller's Avatar
Car: 1967 Firebird P.T.
Engine: LS3 4" Strkr 422ci
Transmission: MN12 6 speed
Axle/Gears: 3.73 8.5" 10 Bolt Eaton
and bellhousing, LS1tech is a good place to find the 3 parts needed to convert, also the gear box sells parts at a reasonable price and the kick back from selling the LT1 parts can reduce the cost tremendously, ive seen LT1 style T56 input shafts for $150, bells for 150-200, that offsets the cost pretty well.
Old Nov 23, 2011 | 02:47 PM
STREETDEMON's Avatar
Car: 91 Z28
Engine: 6.0L LQ9
Axle/Gears: Dana 44 3.92
save yourself the headache and find a good low mileage ls1 t56.....or better yet, if you plan on doing something different with the torque arm, get a mn12.
Old Nov 23, 2011 | 02:56 PM
why? i bolted my stock torque arm onto my MN12 without any modifications....
Old Nov 23, 2011 | 03:00 PM
Car: 91 Z28
Engine: 6.0L LQ9
i was mis-informed on the mn12, i didn't think they had a torque arm provision...must be just the GTO versions.
Old Nov 23, 2011 | 03:01 PM
no, i have a GTO version in my car (2004)
Old Nov 24, 2011 | 07:17 AM
mwfrels's Avatar
Car: '86 Z28
Engine: SDPC TPI 350
Transmission: WC T5
Axle/Gears: 3.23 posi
4th gen f-body torque arm anchor mounts up perfect fit to the GTO M12 T56 I have.
M
Old Nov 25, 2011 | 07:09 AM
M
sure does, i used to think it was different as well but externally, a T56 vs. MN12 there is no difference. Just remember though, if you use it and dont change the bellhousing to an LS1 type, the starter hole is smaller because the GTO's use a smaller high torque mini type starter, i opted for this since i can find them rather easily and it seems to start the car quicker but that might just be me, one disadvantage to using the GTO's starter is lack of supply and cost, the LS1 starters can be found cheap and used on multiple vehicles (cars/trucks/suv's (Lsx)) where GTO starters are 2-3x more expensive (i believe its a mitsubishi starter).
When I was doing my own swap research for a 6 speed i came across this website on the Tech, anyone who wants to use a T56/MN12/M10 or whatever should read this, very informative. Its a 21MB PDF so give it a minute or two to load, its worth it.
http://www.eecis.udel.edu/~davis/z28..._Fbody_T56.pdf
Old Nov 25, 2011 | 08:40 AM
Car: 91 Z28
Engine: 6.0L LQ9
good info to know!
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
hokis
Aug 9, 2015 03:57 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
