few question the sticky doesnt answer
Old Dec 7, 2011 | 09:49 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
iv rear the sticky and searched but i havent found what im looking for, im going to be replacing my 2.8 with a lt1. after i do this i know i need new moter mounts, harness, computer, tranny, springs. but what i need help on is the little other stuff. what i get my springs do i need to do the rear springs aswell or will they be fine with the v6 springs still back there? when i do the tranny do i need to change out the tranny cross member? sway bars? shocks and struts dont matter i hope. reason i say that is i just replaced my rear shocks and will be replacing the struts and strut mounts in the spring.
Old Dec 7, 2011 | 10:57 PM
DiabolicalRS's Avatar
Car: '90 Camaro
Engine: 305 tbi
Axle/Gears: 9 bolt posi 373
Re: few question the sticky doesnt answer
cross member would depend on what trans your gonna go with. if im correct.
Old Dec 7, 2011 | 11:00 PM
58mark's Avatar
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
yes, Hawks sells third gen crossmembers for whatever tranny you're looking at
i
Old Dec 8, 2011 | 05:25 AM
Engine: L31 350
Just the 700r4 for a v8
Old Dec 8, 2011 | 07:20 AM
58mark's Avatar
I'm 99% sure that your existing crossmember will still work,
In answer to your question about the springs, The change in springs is to compensate for the extra weight of the v8 block. Shouldn't effect the back end of the car in any significant way
Old Dec 8, 2011 | 03:17 PM
Engine: L31 350
So all I need is the fronts? I might do the rears if I have the extra. I'm hoping someone will chime in that has the v8 cross member and can verify that idontbneed a new one
Old Dec 8, 2011 | 03:18 PM
Engine: L31 350
What about the sway bars?
Old Dec 8, 2011 | 04:43 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
No need to change any suspension parts, other than the front springs.
Old Dec 8, 2011 | 05:06 PM
Engine: L31 350
Sweet. Thank you guys. Am I missing anything from my list in my first post? Just need to make see I have all my chickens in a row you know?
Old Dec 8, 2011 | 07:06 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I assume you're talking about the V6 to V8 sticky. You'd better read the LT1 swap sticky as well.
Some people keep the V6 front springs. If your LT1 has aluminum heads and if you delete AC, your V6 front springs may work. I used V6 front springs for my LS1/T56 swap, and kept the V6 rear springs for the LS1/4L60E swap.
I don't seem to have a good stance pic of the LS1/4L60E. Here's the LS1/T56:
Old Dec 8, 2011 | 09:24 PM
Engine: L31 350
im deleting ac and the smog stuff, including cat, or might get a high flow cat. if i can find aluminum heads ill get them, other than that the iron heads will suit me
Red iroc-z 305
Sep 30, 2015 05:22 PM
TEEZER TA
Aug 30, 2015 06:35 PM
Bryan F
Aug 18, 2015 02:28 PM
redmaroz
Aug 16, 2015 11:40 PM
bamaboy0323
Aug 15, 2015 07:20 AM
