Crazy ?
Old Feb 13, 2012 | 12:54 PM
motenkjr's Avatar
Car: 1985 Camaro
Engine: 305 ci
Crazy ?
Would it be ok to put engine and trans in before the harness gets back or just wait? I tried to search but couldn't find anything. Thanks guys.
Old Feb 13, 2012 | 01:29 PM
BlueZee28's Avatar
Engine: Cammed 6.0L LSX
Re: Crazy ?
It's easier to plug all the connections in with the harness on the engine before you drop it in the car. Plus it's easier to route the bulk of the harness without the firewall and everything being in the way.
Old Feb 13, 2012 | 01:30 PM
motenkjr's Avatar
Car: 1985 Camaro
Engine: 305 ci
Re: Crazy ?
Ok. Thanks bro
jamieschott's Avatar
Re: Crazy ?
Some folks swear by installing engine with harness installed and PCM end draped over top of engine. Really is what you find easier.
Old Feb 13, 2012 | 01:43 PM
motenkjr's Avatar
Car: 1985 Camaro
Engine: 305 ci
Re: Crazy ?
Yeah. I was just try a c what I can get done before hand. It's been 2 years and I'm anxious to hear my girl run.
Old Feb 13, 2012 | 02:56 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: Crazy ?
i actually did my harness in car. some like to have it out, others in.
Old Feb 13, 2012 | 03:17 PM
POP6482's Avatar
Car: 1989 Iroc-Z Convertible
Engine: 6.0 LQ4 LSX
Axle/Gears: Moser 12 bolt w/4.11s
Re: Crazy ?
I will also be doing my wiring harness with the motor in the car.
Old Feb 13, 2012 | 04:15 PM
88FormulaKiller's Avatar
Car: 1967 Firebird P.T.
Engine: LS3 4" Strkr 422ci
Transmission: MN12 6 speed
Axle/Gears: 3.73 8.5" 10 Bolt Eaton
Re: Crazy ?
+1
Old Feb 17, 2012 | 06:01 PM
motenkjr's Avatar
Car: 1985 Camaro
Engine: 305 ci
Re: Crazy ?
Thanks. Another question....the fuel sending unit has 4 lines coming off of it, a supply line, and a return line..what are the other two for? And what do I do with them?
Old Feb 19, 2012 | 11:43 AM
motenkjr's Avatar
Car: 1985 Camaro
Engine: 305 ci
Re: Crazy ?
Anyone?
Old Feb 20, 2012 | 06:37 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: Crazy ?
you should have one send, one return, one vented check valve, and one that is for the evap system that goes to the front of the vehicle
Old Feb 28, 2012 | 07:50 PM
motenkjr's Avatar
Car: 1985 Camaro
Engine: 305 ci
Re: Crazy ?
Also is there a difference between the truck and fbody crank pulley? More importantly, can I use the truck crank pulley with he ret of the fbody FEAD?
Old Feb 28, 2012 | 09:51 PM
1badeagle's Avatar
Car: 1984 Formula ws6
Engine: 370 LSX
Transmission: 4L80E with a brake and 4500 Stall
Axle/Gears: Moser 9" 4.30 gear
Re: Crazy ?
They are different. I had to get a new one.
Old Feb 28, 2012 | 11:12 PM
motenkjr's Avatar
Car: 1985 Camaro
Engine: 305 ci
Re: Crazy ?
Seriously? So I can't use the truck one...damn! Smh. Any idea how much this is gonna cost me and where?
Old Feb 29, 2012 | 06:58 AM
rickyzZ28's Avatar
Car: 1990 RS
Axle/Gears: 3.73 9 bolt
Re: Crazy ?
I have a used Camaro crank pulley I would be willing to part with as I have a SLP underdrive pulley on my car. PM if interested.
Old Feb 29, 2012 | 07:32 AM
motenkjr's Avatar
Car: 1985 Camaro
Engine: 305 ci
Re: Crazy ?
Pm'd
Old Feb 29, 2012 | 08:43 PM
86White_T/A305's Avatar
Car: 1987 TransAm Ttop
Engine: 2005 LQ4
Transmission: Ls1 T56
Axle/Gears: 3:54
Re: Crazy ?
I found it easier to put my harness in the car first and then I dropped the motor/trans then plugged the sensors in.I prewired the harness and shortend and lengthened what I wanted with the motor on the stand.Then put the harness through the firewall etc.Everyone has their method..either way works just fine.
Old Feb 29, 2012 | 09:52 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Re: Crazy ?
I like any method that minimizes time spent stooped over the fender.
Old Feb 29, 2012 | 11:06 PM
motenkjr's Avatar
Car: 1985 Camaro
Engine: 305 ci
Re: Crazy ?
The reason why I'm asking is bc I'm waiting on my harness to get ready and the city is getting in my butt for the car not working. So if I show progress then maybe they'll leave me alone lol.
Pac J
May 17, 2020 10:44 AM
Rousseau92maro
Feb 1, 2016 05:12 PM
Rocket-Doc
Nov 14, 2015 02:08 PM
SRKLEGIN
Sep 30, 2015 07:19 PM
Zell1luk
Sep 29, 2015 10:36 AM
