Lt1 cam install
Old Feb 16, 2012 | 05:20 PM
keeslinger31's Avatar
Car: Camaro RS
Engine: obd2 350 lt1
Lt1 cam install
The good old lt1 is getting some work done for spring and i finally gathered some parts
Lt4 hotcam prw 1.6 lt4 springs
Victor reinz .26 gasket Can i use stock pushrod length for my setup still?
compcams lifters too
So can i use the stock pushrod length 7.200 for this setup with .26 gasket, and
what does that bring compression to? like 10.7 or higher?
I did some work to the heads. Not much but it should be noticable im hoping for around 350-360rwhp i dont think thats too optimistic
Old Feb 16, 2012 | 06:06 PM
chevyowner02's Avatar
Car: 1992 camaro
Axle/Gears: 3:73
Re: Lt1 cam install
You might get away with the stock push rod length,but I would check to be sure.
Also make sure the dowel pin is at the correct length or you will go through the opti's
Old Feb 17, 2012 | 07:49 PM
Car: Camaro RS
Re: Lt1 cam install
Alright Going out to work on it. Well see how far i get...
Old Feb 17, 2012 | 08:57 PM
TheMonster's Avatar
Car: 1983 Z28
Engine: Forged 355
Re: Lt1 cam install
Push rod length should be the same, what heads do you have?
Old Feb 17, 2012 | 09:12 PM
Car: Camaro RS
Re: Lt1 cam install
They are stock the only thing i changed is the gasket
Old Feb 17, 2012 | 09:23 PM
TheMonster's Avatar
Car: 1983 Z28
Engine: Forged 355
Re: Lt1 cam install
Probably 11:1 compression
Old Feb 18, 2012 | 12:05 AM
Car: Camaro RS
Re: Lt1 cam install
hmmm thats quite high. Good so what kind of power do you think this thing will put out?
Old Feb 18, 2012 | 12:00 PM
TheMonster's Avatar
Car: 1983 Z28
Engine: Forged 355
Re: Lt1 cam install
I don't know too much about lt1 engines but probably pushing 400 fly wheel hp
Old Feb 18, 2012 | 01:48 PM
Car: Camaro RS
Re: Lt1 cam install
Nice thats about what i thought. Im not getting anywhere at all with this.
The head on the passenger side is still bolted on. I haven't even verified if its all okay under there lol this could turn into a much bigger project if i find something.
Old Feb 21, 2012 | 06:02 PM
cprmn14's Avatar
Car: 91 RS
Engine: LTwon
Axle/Gears: Both
Re: Lt1 cam install
Subscribed
Old Feb 21, 2012 | 06:17 PM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Re: Lt1 cam install
I think those are the best rocker arms they make use them all the time. Talked with a bro that ran alum. and he said they flexed so much at 8,000 that it put a valve through the piston.
Old Feb 29, 2012 | 10:24 PM
gm muscle's Avatar
Car: '89 Iroc-Z
Engine: 5.7 TPI
Transmission: 700 R4
Axle/Gears: 2.77
Re: Lt1 cam install
Kinda interested to know if you've made anymore progress.
Old Feb 29, 2012 | 11:37 PM
Car: Camaro RS
Re: Lt1 cam install
Oh you know just being lazy i need to order a timing chain. i think im going with the cloyes 3145 as my stocker had way too much slack. And i have the ewp
I also think im going to get some pushrods and retainers locks valve seals and arp studs or bolts undecided. Also need oilpan gasket and timing chain gasket.
I know im slow... Also read some scary info on heads and cam on semi high mile motors and bearing warping causing spun bearings. Im not sure whether to opt in and build the motor entirely or after i spin a bearing
All in all i think ill ignore it and move on hehe will update tomorrow
Old Mar 14, 2012 | 02:53 AM
Car: Camaro RS
Re: Lt1 cam install
Got some motivation today. really want to drive this thing again.
Here she is as she sits... Got a new camera can't wait to get it outside
Heads are finally off!
Cam is out! New one doesn't look much bigger if at all
But the old one is wore out
New founders lca's relo brackets and adjustable phb
Another go around on these beautiful rockers and so cheap!
Still need to order gaskets and chain. Later today im going to clean up the other head and clean up the block grab some gaskets and a chain from autozone and then put this punk together
Old Mar 14, 2012 | 03:36 PM
Car: Camaro RS
Re: Lt1 cam install
Okay so im having trouble deciding what im going to do about the chain.
My stock one has quite a bit of slop installed.
Should i just grab a replacement from autozone or what?
I learned i can't fit the cloyes 3157 because i have obd2 and the crank sensor.
its frustrating to be this far and not able to continue because of some cheap parts
Its begging for attention
Old Mar 14, 2012 | 06:21 PM
Car: Camaro RS
Re: Lt1 cam install
Goodness, does anyone know what valve seals i should get?
11/32 and 558 or 560 or what size is it supposed to be?
Old Apr 3, 2012 | 04:19 PM
Car: Camaro RS
Re: Lt1 cam install
its 558 I got the alexparts ones.
Old Apr 3, 2012 | 05:12 PM
Brando5641's Avatar
Car: 1998 Trans/Am, 1989 RS Camaro
Engine: LS1, LQ9 6.0
Transmission: 4L60E, 4L60E
Axle/Gears: 2.73, 2.73
Re: Lt1 cam install
I threw a new chain on my 97 lt1 and havent had any issues.
Old Apr 3, 2012 | 06:44 PM
Car: Camaro RS
Re: Lt1 cam install
Haha me too but then I broke pan gasket twice putting timing chain cover on.
So now its coming out... not anymore, finally fitted the pan gasket and cleaned off the passenger side pistons, put on the victor reinz .026 gasket and bolted the head down.
Checking pushrod length was late at night need to go out and do it again to see if its any better this is with the stock 7.200 pushrod. I really need a 7.1770 pushrod to be centered. With a stock gasket of .049 and the new one is .026 thats .023 so 7.200 - .023 = 7.1770 Right? but nobody makes that length... what do I do?
Heres the sharpie imprint I got showing the tip on the exhaust side
Old May 31, 2012 | 10:19 PM
Car: Camaro RS
Re: Lt1 cam install
Got it all done. Having some minor difficulties with the pan gasket leaking
going to use my dads lift to get a better go at it.
And with the roller rockers screaching when they get loose lol crazy
best video of the sound. This is untuned feels way faster. My re-tune is on the way from Pcmforless
http://youtu.be/fVrC4ZdG5Xo
1984HO
Mar 19, 2021 11:59 AM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
anesthes
Mar 10, 2016 10:35 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
