Ls1 air intake set ups
Old Mar 22, 2012 | 12:42 PM
513camarors91's Avatar
Car: 91 camaro rs
Engine: ls6
Transmission: mn12
Axle/Gears: s60 3.73
i am trying to figure out what i am going to do for my air intake set up for my ls1 t56 swap im doing. i have it all mocked up right now but keep going back and forth. right now i have a k&n 04 gto cold air intake that fits good. ive seen a few ppl running them and they look good. the other rought i was going to go was make my own from 4 in pipeing from intakehoses.com and run it down in the driverside batt. tray in front of the tire. the only reason im doing it that way is to keep it cold air and not just hot air thats under the hood. ive heard the k&ns are pretty restrictive and the 4 inch will have a better gain. so i want to see what you guys think or what you have done on your own swap. post pics and let me know..thanks
Old Mar 22, 2012 | 05:30 PM
1nasty86's Avatar
Car: 1986 camaro
Engine: ls2
Transmission: FLT stage 6 60e
Axle/Gears: 8.8 with 3.73's
Re: Ls1 air intake set ups
I bought a airaid you-build-it kit... Came with a single peice of assorted bends and its made of hard pladtic so no heat soak on your iat sensor. Worked perfect for me and mines 4 inch.
Old Mar 22, 2012 | 06:01 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
built mine from scratch. a bit crazier than necessary though; keeping MAF screen, so i can safely move it closer to the filter without issue and get rid of a couple pieces/adapters
Old Mar 22, 2012 | 09:08 PM
POP6482's Avatar
Car: 1989 Iroc-Z Convertible
Engine: 6.0 LQ4 LSX
Axle/Gears: Moser 12 bolt w/4.11s
I went with building my own intake. Although I haven't had the car on the road yet, it fits well.
There have been a few other people running this style CAI. That is where I got the idea from.
Old Mar 22, 2012 | 10:14 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
slp dual cold air, made the center just for the ls1 and used the larger truck MAF
Old Mar 23, 2012 | 09:04 AM
Car: 91 camaro rs
Engine: ls6
Transmission: mn12
now i wanted to run 4 in all the way but i cant bc of the maf reduces to 3.5..i know you can convert to speed density if i remember and get rid of the maf. is there any benifits or cons to doing it..or is there any other way i can run 4 inch all the way...then again i don't know if the motor really needs 4in all the way bc its not a built motor just basic. heads cam headers.
Old Mar 23, 2012 | 09:32 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
i've got the 85mm truck MAF and its just under 4" (i think i had to adapt to 3 7/8" to get a really snug fit with the couplers).
Old Mar 23, 2012 | 10:38 AM
Car: 91 camaro rs
Engine: ls6
Transmission: mn12
ive found a 100mm maf from texas speed witch its 4in..i was thinking about running this so i could stay 4in all the way through. but its going to be 250 just for the maf
Old Mar 23, 2012 | 10:44 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
you wana play, you gotta play...
Old Mar 23, 2012 | 01:38 PM
88FormulaKiller's Avatar
Car: 1967 Firebird P.T.
Engine: LS3 4" Strkr 422ci
Transmission: MN12 6 speed
Axle/Gears: 3.73 8.5" 10 Bolt Eaton
ill have a thread up soon when i fab a custom ram air box for the RAII hood on my firebird.
Old Mar 23, 2012 | 01:44 PM
Car: 91 camaro rs
Engine: ls6
Transmission: mn12
has anyone got rid of the maf and gone with speed density?...that was another thought just so i wouldnt have to buy a new maf...i know i would have to get a tune but i will need one anyways for the cam and heads im running
Old Mar 23, 2012 | 02:15 PM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Whats the rest of your set up? What throttle body are you running? The 102?
For the record...Im running the FAST 90 with a NW 90mm TB. I decided to run the 85mm Z06 MAF. A 85mm truck MAF will also do the trick. It was fairly cheap, flows PLENTY good, and is pretty incognito. Easy to tune and is in no way choking anything out.
I just cant see spending $250 on a 4" MAF when ~$150 gets you a truck or Z06 MAF and will work just fine for you. Unless you are trying to sneak every little pony out of the set up. But Im willing to bet you wont notice unless it truely is the restriction in your intake system.
Just my opinion. Tho the 4" system with that nice billiet piece would look nice...not denying that!
J.
Old Mar 23, 2012 | 02:53 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
I'm right there with you; I paid $50 for my 85 and it incorporates the IAT sensor, so one less piece to try and find a home for.
Old Mar 23, 2012 | 04:00 PM
Car: 91 camaro rs
Engine: ls6
Transmission: mn12
im just running the ls6 intake with shanner II ported tb for now but plan on doing a fast intake wen money comes around..
Old Mar 23, 2012 | 07:29 PM
Car: 86 Trans AM
Ide just grab an 85mm then. You'll see little to no gain right now by getting crazy with the MAF size. 1ADan brought up the other good point...that the 5 wire MAFs house the IAT sensor built in. Im not running the internal IAT myself. But only because my harness was set up for the separate sensor, and I just never changed it.
When you go to an aftermarket intake, unless you step up and get the 102, you will still be fine with that 85mm MAF. If you do step up to the 102, then at that point you're already spending a LARGE chunk of change. Whats an extra 250 for the big 4" MAF
J.
Old Mar 24, 2012 | 02:39 AM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
Sweet Jebus that awsome. if I had the coin Id go for it. What motor is it meant for as it doesnt look like anything If seen
Old Mar 24, 2012 | 04:30 AM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
I bought a plastic MAF housing 100mm from, http://www.powrmax.com/PowrMAF%20100.html
This avoids heat soak of a metal housing, and it uses stock GM MAF card.
Old Mar 24, 2012 | 09:28 PM
Car: 91 camaro rs
Engine: ls6
Transmission: mn12
its ment for the lsx motors...texas speed sells them...very nice piece
Old Mar 27, 2012 | 04:41 PM
Flip 2's Avatar
Car: 1983 Firebird SE
Engine: C5 LS1
Transmission: 6 speed
POP6482
Very nice. You might want to be careful about driving in deep puddles. Ghettocruiser sucked a bunch of water and locked a engine. Never did hear what the situation was, but ouch. He's weighed in on this thread, without comment, so could be ok.
Old Mar 27, 2012 | 08:54 PM
POP6482's Avatar
Engine: 6.0 LQ4 LSX
Thanks. The car doesn't see much rain unless I get stuck at a show or cruise during a t-storm. I did fab up a piece of plastic yesterday for the wheel well. This will cut down on any dirt getting to the filter.
Old Mar 28, 2012 | 10:00 AM
Car: 91 camaro rs
Engine: ls6
Transmission: mn12
yeah i think im doing the same thing as you and im going to run it down out of the engine bay infront of the tire. then make a sheild so rock and water doent beat the filter....im going to attemp to run 4in all the way...ordered it all from intakehoses
Old Mar 28, 2012 | 10:12 AM
POP6482's Avatar
Engine: 6.0 LQ4 LSX
Made my plastic shield on Monday. Went to Lowes and as soon as I walked in say a black mixing trough for $4. Got some screws and black spray paint.
Old Mar 28, 2012 | 01:02 PM
6SIX6's Avatar
Car: 89 IROC
looks better now and will keep the water out. Good job man
Old Mar 28, 2012 | 01:59 PM
Car: 91 camaro rs
Engine: ls6
Transmission: mn12
nice work....
Old Mar 29, 2012 | 07:19 AM
Car: 86 Trans AM
Yup...I was only commenting on the MAF choices.
My problem was it was sunny and awesome when I left for work. Then when I was heading out, there was a massive downpour. I waited a while...didnt expect there to be flooding. I ended up in a puddle that was WAY deeper than I thought, and my filter was just about submerged. I had no chance. By the time I realized how deep it was, it was too late. I also just rolled into it. REALLY hate myself to this day...even though its being rebuilt haha.
Until that point, I had driven in rain before. Hit puddles, etc. Wet roads and smaller puddles dont really get to the filter in that location. Maybe a teeny bit, but not enough to put any water into the intake. Never any issues until I tried to submarine it.
That location is FANTASTIC for IAT's and throttle response though!! My IATs were always around ambient. Or higher if sitting in traffic due to the hot pavement. Just have to be careful. When i get mine running again, Im going to keep my set up as it is. HOWEVER...Im keeping a cheap filter and a couple fittings in my hatch. Im using a quick release clamp, and if its gonna rain, Ill just hot swap the filter arrangement. One day of sucking in hot engine bay air is better than going through this again.
J.
Old Mar 30, 2012 | 05:56 PM
Engine: ls1, LB9
thats why pulling from the fenders maybe a better choice. my air temps are always very low so its not like your giving up flow and temp. just less chance of hydro locking
Old Apr 2, 2012 | 01:38 PM
6SIX6's Avatar
Car: 89 IROC
finished what my intake will be for this year or till I change it if it doesnt work out
Old Apr 4, 2012 | 11:46 AM
Car: 91 camaro rs
Engine: ls6
Transmission: mn12
here is the set up i decided to go with...i runs into the tray into the fender...it 4 inch all the way...im not done yet..
Old Apr 4, 2012 | 11:47 AM
Car: 91 camaro rs
Engine: ls6
Transmission: mn12
Car: 91 camaro rs
Engine: ls6
Transmission: mn12
1992 Trans Am
May 10, 2023 07:19 PM
kyle5647
Aug 15, 2015 11:56 PM
Jake_92RS
Aug 11, 2015 10:39 AM
bryan623
Aug 10, 2015 11:33 AM
