ls2 swap
Old Mar 30, 2012 | 11:51 AM
blue90z28's Avatar
Car: 1990 camaro iroc
Engine: 350 vortec tpi
Transmission: built 700r4 3500 stall
Axle/Gears: 10 bolt 3.42 posi
ls2 swap
Getting a ls2 out of a 06 gto and need to know what all parts i need for the swap
Old Mar 30, 2012 | 11:59 AM
88FormulaKiller's Avatar
Car: 1967 Firebird P.T.
Engine: LS3 4" Strkr 422ci
Transmission: MN12 6 speed
Axle/Gears: 3.73 8.5" 10 Bolt Eaton
Re: ls2 swap
if only the answers came so easy
i spent probably 100 hours of reSEARCHing... when i did mine
theres a word in there...
SEARCH
Old Mar 30, 2012 | 12:02 PM
1nasty86's Avatar
Car: 1986 camaro
Engine: ls2
Transmission: FLT stage 6 60e
Axle/Gears: 8.8 with 3.73's
Re: ls2 swap
Lol yeah... There ar only 2867659382792 threads in the lsx section... Also check out ls1tech
Old Mar 30, 2012 | 12:44 PM
coptzer's Avatar
Car: 1986 IROC-Z
Engine: LS1-ish
Transmission: T56 stage II
Axle/Gears: S60 4:10's
Re: ls2 swap
SEARCH
There is just way too much info out there to easily say, "this is what you need". Go through and read the stickies and get more familiar with it first. Good luck.
Use this sticky link:
https://www.thirdgen.org/forums/ltx-...third-gen.html
Here is a snippet from it--
Where to start?
First thing you need is obviously an engine and transmission. All LS engines are externally the same regardless of origin. Whether it be from a truck, F body, Corvette, or GTO, they are all the same architecture, although there are vast differences in accessory drives, intake manifolds, and oil pan configurations. Being that the fourth gen and third gen f-bodies are so similar in so many ways, it is by far the easiest to swap a complete fourth gen f-body LS1 drop-out into your third gen. The accessory drives all fit under the hood and the oil pan clears. Truck engines offer only a usable long block and wiring harness as the oil pan, accessories, and intake manifold all need to be changed to fit into the third gen engine compartment. Corvette oil pans also do not fit and although the accessories fit it is not as good a match as a fourth gen set up. At the present time we are not certain of GTO pieces, so if you go this way post up your results. Worth noting that Corvettes use a transaxle set up so the engine is all that is usable.
Old Mar 30, 2012 | 12:46 PM
Re: ls2 swap
Actually, i take it all back, send me a paypal pymnt of $25 and ill send ya an excel spread sheet of all major parts needed.
Old Mar 30, 2012 | 12:54 PM
blue90z28's Avatar
Re: ls2 swap
I might just do that when i get paid thanks
Old Mar 30, 2012 | 12:58 PM
blue90z28's Avatar
Re: ls2 swap
Where to start?
Thank you and i would go the forth gen route but im getting it for 1500 but no harness so when i gather all the parts i will definitly post up results
Old Mar 30, 2012 | 01:03 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
Re: ls2 swap
What do you all need....in short about $10k lol
Old Mar 30, 2012 | 01:08 PM
blue90z28's Avatar
Re: ls2 swap
Is that including engine
Old Mar 30, 2012 | 01:14 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
Re: ls2 swap
These are all on the extremely low side:
Trans and clutch 2k
Motor/cam/springs etc, Pull-out 1750, rebuilt 3k
Intake/injectors/tb 300-1000+
Fuel system for ~550 horse 500
Mounts 300
Exhaust 1200
Msc **** that you can't do without 1000
Tune 600
Here is what i was up to about 3k ago...https://www.thirdgen.org/forums/ltx-...ted-lsx-t.html
Old Mar 30, 2012 | 01:33 PM
blue90z28's Avatar
Re: ls2 swap
Motor runs good its in my friends car hes just going with a lsx 454 motor has around 40,000 on it for 2k it would include the serphantine n ecm 1500 without that
Old Mar 30, 2012 | 01:44 PM
blue90z28's Avatar
Re: ls2 swap
89 roc z nice job
Old Mar 30, 2012 | 06:10 PM
coptzer's Avatar
Car: 1986 IROC-Z
Engine: LS1-ish
Re: ls2 swap
$1500 for an LS2 motor with 40k on it is pretty good.
Old Mar 30, 2012 | 06:20 PM
1nasty86's Avatar
Car: 1986 camaro
Engine: ls2
Re: ls2 swap
throw a cam, springs, new oil pump and timing chain in it while your at this stage too.... You wont regret it... My friends car has a 232/236 in his and it would be a nice cam for a ls2.... Or just throw a vrx5 in it and ride!
Old Mar 30, 2012 | 06:58 PM
blue90z28's Avatar
Re: ls2 swap
Whats a vrx 5
Old Mar 30, 2012 | 07:01 PM
blue90z28's Avatar
Re: ls2 swap
Anyone know if a ls1 harness will work
Old Mar 30, 2012 | 08:42 PM
coptzer's Avatar
Car: 1986 IROC-Z
Engine: LS1-ish
Re: ls2 swap
Whats a vrx 5
This is a vrx5 ---- https://www.vengeancerd.com/ecart/pr...7D.605-113-LSA
Nice BIG cam - we are talking maybe 430+ with this bad boy and the right setup and tune.
Old Mar 30, 2012 | 10:23 PM
1nasty86's Avatar
Car: 1986 camaro
Engine: ls2
Re: ls2 swap
this is why i suggested this cam.. typed from vengence............................................ ** Our #1 Camshaft in daily driven LS2 equipped Vettes/GTOs/CTSVs.**
Old Mar 31, 2012 | 08:11 AM
coptzer's Avatar
Car: 1986 IROC-Z
Engine: LS1-ish
Re: ls2 swap
I love the lump of that thing. Good recommendation! Is this what you are running Nasty?
Old Mar 31, 2012 | 09:46 AM
1nasty86's Avatar
Car: 1986 camaro
Engine: ls2
Re: ls2 swap
Nooo, im running a 239/246 .623/.615 112+3
E Rod
Aug 28, 2015 05:17 AM
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
355sbcTPI
Aug 19, 2015 04:38 PM
Thirim
Aug 13, 2015 03:09 PM
