Ls1 throttle cable
Old Sep 14, 2012 | 02:56 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Ls1 throttle cable
What cable are you guys using? Cheaper the better. My TPI cable is a big fat no, my carb setups live a TBI cable all day.
Old Sep 14, 2012 | 03:42 PM
Marc 85Z28's Avatar
Re: Ls1 throttle cable
I'm using a non-traction control cable from a 99 Camaro. It had to make a custom grommet for the firewall and modify the pedal end to mate to my stock pedal.
Old Sep 14, 2012 | 04:09 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Any pics? I was hoping I could use a stocker, I think I could use a LT1 cable? Think the last time I used a TBI cable in a LT1 car, it mated to the has petal like stock when I used a carb.
Old Sep 15, 2012 | 04:53 AM
Jaysz28's Avatar
Car: 91 Firebird
Engine: 6.0
I used the same cable for my swap
its a tad long though, so I tied a not at the pedal end to take up the slack rather than bending the pedal
Old Sep 15, 2012 | 01:05 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Ditto to the above. 99 cable. Had to bend the pedal arm back a tad to reach WOT. 5 minute job.
Old Sep 15, 2012 | 02:09 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Well, seems I can make a bracket that will take the slack up then.
Old Sep 15, 2012 | 07:29 PM
Marc 85Z28's Avatar
Tie a knot in the cable? Bend the pedal?
I cut the pedal end of my 99 cable to match the stock cable, then crimped and brazed on a new end that fit the stock pedal.
Old Sep 16, 2012 | 01:11 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Well, many a option, at least 4, lol.
Old Sep 20, 2012 | 06:54 PM
Pocket's Avatar
Car: 91 Trans Am
I put zipties on the cable to take the slack up vs bending the pedal arm. Took 5 mins
dbrochard
Sep 19, 2015 08:13 PM
TheTraut88
Sep 11, 2015 05:16 AM
TheTraut88
Sep 7, 2015 05:22 PM
Randomtask2
Sep 7, 2015 05:06 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
