Capping LT1 water pump elbows
Old Oct 13, 2012 | 05:41 PM
BCdawg57's Avatar
Car: '91 Z28, '13 Civic EX-L
Engine: 355 LT1, 1.8 I4
Transmission: T56, 5spd auto
Axle/Gears: 10 bolt 3.42(as long as no breaky)
I need to know a better way to cap off some elbows on my water pump. I have tried rubber ones with a hose clamp, but they always crack and either start leaking or pop off completely. Anyone have any ideas?
Old Oct 13, 2012 | 06:11 PM
cprmn14's Avatar
Car: 91 RS
Engine: LTwon
Axle/Gears: Both
Re: Capping LT1 water pump elbows
for my lower radiator outlet on the water pump, i took out the elbow off and replaced it with a 3/4" freeze plug from NAPA.
Old Oct 13, 2012 | 09:12 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Buy a vette pump.
Old Oct 13, 2012 | 10:08 PM
DIGGLER's Avatar
i think i removed mine, tapped the holes, and installed npt plugs.
Old Oct 18, 2012 | 09:54 AM
BCdawg57's Avatar
hmm thanks for the ideas. Im not really looking to buy a new pump. I may try threading the holes. I figured there would be some way to crimp a cap on the end of the elbow or somethings less invasive.
Old Apr 3, 2013 | 09:57 PM
BCdawg57's Avatar
how did you guys go about removing the elbows?
Old Apr 6, 2013 | 02:39 PM
BCdawg57's Avatar
anyone? i was going to hit them with a hammer and try and work them back and forth to get them out. Will this work?
Old Apr 18, 2013 | 03:36 PM
artimus's Avatar
hello I do also had this water pump issue. I was stick in a rubber grommet and put plastic caps on them. but as it turns out im now leaking form the weap hole. but befor that i had no leaks. im going to replace the pump with the 92 vette pump. cause it has less holes to cap off. hope this helps.
Old Apr 18, 2013 | 05:24 PM
cprmn14's Avatar
Car: 91 RS
Engine: LTwon
Axle/Gears: Both
I just took a big rubber mallet and gave it a good whack. Its just held in by a hardner and once it breaks free it comes right out.
Old Apr 18, 2013 | 11:20 PM
artimus's Avatar
Cprmn14 I would like to see how u did ur plugs. And how u threaded it. Pics plz thanks man
eightsixseven
Dec 16, 2024 01:50 PM
evilstuie
Jan 9, 2020 08:29 PM
evilstuie
Apr 14, 2016 08:52 PM
1985chevydude
Aug 22, 2015 05:36 AM
Dialed_In
Aug 20, 2015 01:45 PM
