knocking hitting?
Old Nov 29, 2012 | 07:37 PM
rock861261's Avatar
knocking hitting?
I need your help guys what is this?
Old Nov 30, 2012 | 08:22 AM
dprest68's Avatar
Car: 1989 Pontiac Trans Am GTA
Engine: cammed LS1
Transmission: Monster SS 4L65E
Axle/Gears: 9 bolt posi w/ 3.70 gears
Re: knocking hitting?
I'm not sure what it is, but I definitely wouldn't be running the engine with it doing that!
Old Nov 30, 2012 | 08:52 AM
Flip 2's Avatar
Car: 1983 Firebird SE
Engine: C5 LS1
Transmission: 6 speed
My quick take:
If the pulley is loose, it is probably the pulley.
If the pulley is not the culprit, it could be a rod bearing.
If pulley, you probably need a new one, plus bolt and key.
Also need to borrow a 150 lb torque wrench... what is it 130 ft lbs on the crank bolt? Something VERY snug Pulley could have come loose from wimpy torque wrench.
Rod bearing??? Out she comes.
Good luck.
Old Dec 1, 2012 | 06:54 PM
Pocket's Avatar
Car: 91 Trans Am
Its not a rod knock
Old Dec 1, 2012 | 07:30 PM
dprest68's Avatar
Engine: cammed LS1
It's 240 ft. lbs. according to the information I have. Stock LS1 balancers don't have a keyway. Also, make sure the balancer is pulled onto the crankshaft correctly. Do not use the balancer bolt to pull it on!
Old Dec 2, 2012 | 12:08 PM
Flip 2's Avatar
Engine: C5 LS1
Well, I was right about the stout part-LOL.
Old Dec 8, 2012 | 07:14 PM
Brando5641's Avatar
Car: 1998 Trans/Am, 1989 RS Camaro
Engine: LS1, LQ9 6.0
Transmission: 4L60E, 4L60E
Axle/Gears: 2.73, 2.73
Originally Posted by Pocket
Its not a rod knock
I'm with you. I don't believe it could be a main or a rod because with the amount of rotation he is moving it there is no way its a rod or main.
I'm guessing oil pump. Get to yanking it out, motor has to come out anyway.
Scratch that. I just watched the second video.
Sounds like its around the flywheel.
Old Dec 8, 2012 | 07:18 PM
rock861261's Avatar
turns out it was a loose flexplate...
RedLeader289
May 28, 2019 01:47 PM
Ed1LE
Sep 30, 2018 09:14 AM
apie2546
Oct 16, 2016 02:24 PM
bigjay89gta
Oct 15, 2015 08:04 AM
efiguy
Sep 27, 2015 01:30 PM
