BRP swap Kit?
Old Dec 2, 2012 | 08:23 PM
david068513's Avatar
Car: 1992 z28/1992 RS heritage edition
Engine: 350 tpi, 305 tbi
Transmission: 700R4,T5
Axle/Gears: G92
BRP swap Kit?
I was looking at using BRP's swap mounts and cross member. Has anyone used them? I most likely will be using there headers also. I was told there kit works with the stock K member but will the mounts bolt up and be fine with a tubular K-member that wasn't built for LS swap? Should be the same as a stock K that the kit was built around correct?
Old Dec 3, 2012 | 09:28 AM
STREETDEMON's Avatar
Car: 91 Z28
Engine: 6.0L LQ9
Axle/Gears: Dana 44 3.92
Re: BRP swap Kit?
don't know anything about the mount kit, but their headers work great with the stock k-member. i have the mids on my 6.0l and i would recommend them to anyone. there shouldn't be any issues with the headers and tubular k.
Old Dec 3, 2012 | 01:51 PM
Axle/Gears: G92
Re: BRP swap Kit?
Thanks for the info. I couldn't find hardly any reviews on any of there parts so was curious as to what people thought of them.
Old Feb 9, 2013 | 08:09 PM
Dustytrix's Avatar
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Axle/Gears: 373 zexel torsen
Re: BRP swap Kit?
Can you post some pics with those mids installed? I am looking into getting some.
Old Feb 11, 2013 | 08:13 AM
Car: 91 Z28
Engine: 6.0L LQ9
Re: BRP swap Kit?
all the pics you need are in my build thread....search for hedman husler mids, you should be able to find it...i think it has resurfaced to the top 2 pages here recently also.....
Old Feb 12, 2013 | 12:12 AM
Axle/Gears: G92
Re: BRP swap Kit?
So still no one knows anything about the mounts? Lol
Old Feb 12, 2013 | 12:35 PM
blakecharles's Avatar
Re: BRP swap Kit?
nope... I was barely able to find the mid's... I want LT's but cannot justify paying 800-1000 for them seeing how this car is just a "toy" that will most likely be ignored for the better part of the year. If you order or found out anything about the swap kit, post it.
Old Feb 12, 2013 | 12:49 PM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Re: BRP swap Kit?
If the mounts are made to fit in the stock place, and you have a tubular k member for stock mounts, I don't see any reason why they would not work.
Old Sep 27, 2016 | 01:49 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: BRP swap Kit?
Bringing a thread back from the dead, I really like the look of this kit. I'll be using a 700R4 behind my LQ9 so I'll have to use a cross member from BMR to make it work. No one else makes a 700R4 cross member for the swap that I can find. The design of the long tubes I think are what I like the best about this.
toronto formula
Nov 10, 2015 06:17 AM
Mickeyruder
Sep 2, 2015 02:45 PM
fasteddi
Sep 2, 2015 10:29 AM
lt1z350
Aug 28, 2015 05:57 AM
