1991 Z28, LSA/2.3 ZR1 blower under stock hood build.
Old Oct 29, 2014 | 12:02 AM
topteam54's Avatar
Car: 68,87,99 maros, 07 tbss
Engine: TPI,LS2,LSA,L92
Transmission: T56,T56,T56, 4L80E
Axle/Gears: 12bolts and 14 bolt lol
Doing a slightly different build. Forged LSA shortblock, with ZR1 supercharger, LPE snout to run LSA accessories, 4L80E (unknown converter), moser 12 bolt.
These are some mock up picks to verify that the stock hood would clear the blower. Now I can proceed with the build.
Old Oct 29, 2014 | 08:28 AM
406TPI's Avatar
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
Re: 1991 Z28, LSA/2.3 ZR1 blower under stock hood build.
BadAss!
Old Oct 29, 2014 | 11:31 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
I've wondered about this since the guy who owns/runs Speartech posted his car. He went through the trouble of moving the water/air heat exchanger to the rear on the blower housing too. are you using Spohn pedestals in the stock location?
Old Oct 29, 2014 | 11:46 AM
topteam54's Avatar
Originally Posted by 406TPI
BadAss!
Yes stock out of the box. I've seen the speartech Camaro (amazing), I think the relocation of the coolant lines was more of a preference than actually needed. They have that cowl hood so I know it wasn't a clearance issue for them.
I might have to modify my coolant line on the driver side. Since the person I purchased the blower from had the coolant lines split. They both normally are on the passanger side. I have no idea the reason for the modification.
Old Oct 29, 2014 | 12:43 PM
Pocket's Avatar
Car: 91 Trans Am
With the flat blower lid, check the engine angle vs the fenders. The spohn stands are notoriously low on the pass side
Splitting the coolant lines is likely a packaging decision. Much easier to run one each direction to the HX and pump than both together for some HX setups
Old Oct 29, 2014 | 12:55 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Split as in separate? That coolant passage on the front isn't stock? Or are you talking about something entirely different? What did that setup run you used? If you don't mind me asking....
You building the engine yourself? You keeping the stock displacement, 6.2L?
topteam54's Avatar
It clears.
Old Oct 29, 2014 | 01:05 PM
topteam54's Avatar
Here's a pic of my buddies V with a ZR1 blower. Notice the coolant lines. Both on passanger side.
Here's my blower. Look how the lines are split. I believe the reason for this is the hot and cool lines aren't side by side. Helping any bit with IATs.
As far as building myself yes and no. Engine was built by Charlie at rpm. Stock LSA crank, Callie's rods, weisco pistons, CNC LPE LSA heads. Comp 9.7:1
The rest of the build will probably be done in house (aside from headers).
Frozer!!!
Jan 19, 2024 04:55 PM
CarGuyDennis
137
Dec 6, 2016 11:02 PM
sailtexas186548
Exterior Parts for Sale
Feb 29, 2016 08:40 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
