Turbo Hotside
Old Jan 19, 2015 | 08:32 PM
LS1BADZ28's Avatar
Turbo Hotside
Does this look like it'd work in a third gen LSx?
Old Jan 19, 2015 | 09:00 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Turbo Hotside
No accessories? You know what turbo is on it to gauge compressor housing diameter?
You can make anything front mount work but likely will have to move rad forward for clearing electric fans. I wouldnt do pusher fans, they dont seem to work as well from what i've seen in a 4th gen
Also want to brace that turbo
Old Jan 19, 2015 | 10:21 PM
LS1BADZ28's Avatar
Re: Turbo Hotside
I plan on moving the radiator...more concerned with the manifolds clearing the master cylinder and that...
Old Jan 20, 2015 | 05:39 AM
Jay_rich's Avatar
Car: 1987 Z28
Engine: 2005 5.3L, LS6 Cam
Axle/Gears: DTS 9" 3.50 TrueTrac
Re: Turbo Hotside
Hard to tell but I would say a manual master cylinder would be needed and 100% moving the rad forward a lot.
Jay
Old Jan 20, 2015 | 07:40 AM
406TPI's Avatar
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
Re: Turbo Hotside
I really doubt it without ALOT of work.
Old Jan 20, 2015 | 07:56 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Re: Turbo Hotside
Yeah does look like it will be very tight on that master cylinder. Any side views of this motor?
Old Jan 21, 2015 | 02:49 PM
cosmick's Avatar
Car: '86 Camaro, '94 Camaro, 3 others
Engine: LG4 ->L29, L32->LR4, L36, LG4, L31
Transmission: 700R-4, T5WC, 4L80E, SM465, 4L60E
Axle/Gears: 3.42, 3.23, WTB/WTT 2.93
Re: Turbo Hotside
I've seen similar done to a 4th gen, but your pic seems to have non-truck exhaust manifolds. Also the turbo needs to be as close to the engine as possible, and lower seems better for fitment. Plenty of space available to move the bottom of the radiator forward, if you're willing to do the work.
You'll need to fab support brackets from the engine block to carry the weight of the turbo, when those pipes get hit they can let gravity pulling on the turbo pull them out of shape if you don't add proper support.
Old Jan 23, 2015 | 07:37 PM
LS1BADZ28's Avatar
Re: Turbo Hotside
Hawks is selling one on ebay...
http://www.ebay.com/itm/82-92-Camaro-Firebird-LSX-LS1-Swap-Front-Mount-Turbo-Kit-76mm-Used-/291359728400?pt=Motors_Car_Truck_Parts_Accessories&hash=item43d664a310&vxp=mtr
Old Jan 24, 2015 | 09:52 AM
cosmick's Avatar
Re: Turbo Hotside
Gotta wonder what the Hawks kit does about the FEAD?
cheesehomer
Dec 31, 2015 08:48 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
bjpotter
Oct 4, 2015 07:48 PM
customblackbird
Oct 1, 2015 04:30 PM
New2Chevy
Sep 28, 2015 12:35 AM
