Will my Flexplate work?
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Hey guys,
I've been reading through the LS forum here while doing my research on what kind of swap I want to do ( 406sbc or LSX), and can't find the answer I"m looking for.
I would keep my 700R, and I know I'll need to get the space, but it uses a 153 tooth flexplate. Will this flexplate work with the spacer needed or do I need to go up to the 168(?) tooth flexplate that I've been reading about on here?
Car: '91 Camaro
Engine: LSx
Transmission: 4l60e
Axle/Gears: posi
Car: '86 Camaro, '94 Camaro, 3 others
Engine: LG4 ->L29, L32->LR4, L36, LG4, L31
Transmission: 700R-4, T5WC, 4L80E, SM465, 4L60E
Axle/Gears: 3.42, 3.23, WTB/WTT 2.93
Re: Will my Flexplate work?
Get the LQ4 / 4L80E flexplate with spacer, then assemble everything, then see if the flexplate needs the holes elongated or redrilled for your torque converter.
Car: 1984 Trans Am
Strange, never heard of a flexplate that small
Anyhow, 4L60E dish and 4L80E flat with adapter flexplates are common and inexpensive. Grab a replacement and dont worry about it
Car: 1984 Trans Am
This thread here where I was talking about my engine buid, post 18 has my build sheet which has the flex plate listed. I verified the p/n and it's this flexplate.
Learned something new
For future reference, any flywheel/flexplate that will bolt up to a 1pc RMS SBC will also bolt up to a common LSx crank. Depth changes, so using a spacer/adapter may or may not be needed
Car: 1984 Trans Am
I will most likely switch because the starter on an LSX is different thatn the old SBC starter right? That is the main driving factor for the number of flexplate/flywheel teeth isn't it?
There isnt a cost effective LSx starter that can reach a 153 tooth fly/flex which is the main limiter for T5 users
Car: 1984 Trans Am
Car: 1984 Trans Am
Oh, yeah, sorry. Anyway, those flexplates are different from BBC 168-tooth flexplates, except the old 2-pc RMS, then except 400 / 454, and those 2 differ, and all of those differ from 168-tooth LSx flexplates.
No matter what adapters you find, you still need either of the 2 LSx flexplates. One is dished, one is flat.
I got a new flat one for an LQ4 / 4L80E, which to my surprise included a 0.400"-thick aluminum spacer and longer bolts, to go with my '96 4L60E, and that worked out perfectly.
The dished LM7 / 4L60E style supposedly just needs a Hughes pilot adapter, or if you're planning serious HP, then TCI makes a SFI-approved flexplate for the LSx.
Transmission: 4L80E/4L80E
A Gen I one-piece RMS flexplate will have the counterweight on it (which is shown in the link to the Pioneer part). LS engines don't use the counterweight.
cosmick has it right. Get an LS flexplate made to mate to an earlier TH700/4L60. (something like this http://www.summitracing.com/parts/ad...make/chevrolet )
(pocket, surprised you didn't know the Gen I SBC flexplates were 153- and 168-tooth - approximately 12-3/4" & 14", respectively.)
The only 153 tooth rings Ive put my hands on were manuals. T5's and various 4 spds
Car: 1984 Trans Am
All I know when I was building the motor, the flex plate I got from the builder was a 153 tooth. It fit, no shims needed on the starter, so I was a logical next step to see if it was something I could use with the adapter or not.
84z96L31vortec
Aug 20, 2017 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
