ls swap 5.3
Old Feb 15, 2015 | 09:33 PM
bizzle88's Avatar
Engine: 355ci
Transmission: th350
Axle/Gears: idk, its disc brake posi
ls swap 5.3
hey folks this is my first post and hopefully I do it correctly and sufficient , but I have a question, Im wanting to do the ol ls swap in the 3rd gen eventually and I came across a 5.3 out of a 06 Silverado, that "got coolant in a cylinder and broke a rod" and its all taken apart but the lowest they will go is $450 on the engine is this good deal or should I pass and wait for another? plans would be to eventually put boost to it, and opinions are appreciated in advanced and thank you! and what ive read is that the newer blocks are aluminum? correct me if im wrong please and thank you
Old Feb 15, 2015 | 10:41 PM
alex722607's Avatar
Car: 1988 Pontiac Transam GTA Notchback
Engine: 2003 Chevy 5.3 Vortec (325 cu)
Re: ls swap 5.3
Just putting it out there, I payed 700 for a complete engine- intake to oil pan
Old Feb 15, 2015 | 10:46 PM
bizzle88's Avatar
Engine: 355ci
Transmission: th350
Re: ls swap 5.3
so in other words wait for better deal? right
Old Feb 15, 2015 | 10:58 PM
alex722607's Avatar
Re: ls swap 5.3
Personally I would. I mean if you get a block cheap, but then have to pour a ton into it just to make it right, it doesnt work out in the end. I mean with mine, my engine burnt oil and I did know that before I purchased it. I ended up dishing out 400 for new reman heads.
IMO (ofcourse) good luck with your decision
Old Feb 16, 2015 | 08:28 PM
Pocket's Avatar
Car: 91 Trans Am
Re: ls swap 5.3
It hydrolocked and snapped a rod. Often the rod stub also goes through the block and/or bangs up the base of the cyl enough to ruin the block
FWIW, Ive had about 20 5.3s and never paid $450 for any of them, ready to run. They're throw away motors
Old Feb 16, 2015 | 09:52 PM
bizzle88's Avatar
Engine: 355ci
Transmission: th350
Re: ls swap 5.3
im gunna pass on the deal being it snapped a rod made me wonder what else happened too, but I value yalls opinions and my search will continue thanks for the responses ;-)
Old Feb 18, 2015 | 09:19 AM
R13_Braz's Avatar
Car: 2014 Z28 #80
Re: ls swap 5.3
I paid $400 for a complete 04 4.8 with 119k miles (including exhaust manifold's). Except for it being dirty, and needing to be flushed out due to sitting, it's practically pristine.
Old Feb 18, 2015 | 10:32 AM
cypris09's Avatar
Car: 87 Gta
Engine: 5.3
Transmission: 4l60e
Re: ls swap 5.3
I paid just over a grand for a 01 5.3 and 4l60e with 98k. Plus ecm and harness. Just a fyi. Plus I heard it run before they pulled it
neilb
Oct 4, 2018 12:36 AM
z28addict8490
Sep 5, 2015 03:56 PM
E Rod
Aug 28, 2015 05:17 AM
nuggie
Aug 25, 2015 01:27 PM
jharrison5
Aug 19, 2015 05:53 PM
