Rookie on lsx
Old Jan 29, 2019 | 01:27 PM
  #51
budget builder's Avatar
Car: 91RS
Engine: carb'd 357 vortec
Axle/Gears: 3.42 posi
Re: Rookie on lsx
https://ls1tech.com/forums/new-ls1-o...l#post20038312
Old Jan 30, 2019 | 06:59 AM
  #52
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Rookie on lsx
Originally Posted by budget builder
Made the agreement to buy... 135k miles from what I was told... unfortunately I was wrong it has everything but the computer... so do I buy a pcm or go carb? Part of me wants to go carb bC of less wiring. A lot less electrical work... but would that hurt my bottom line? Looking as close to 600hp and tq as I can get... natural aspiration **no boost**
600 all motor is going to be more than a stock bottom end build so it doesnt matter what you buy, you just need a crank and block lol
its possible to get more like 550’s hp. Good head and cam, typically 450-475 whp give or take. Bore it out to make it closer to a ls3 and use ls3 heads top end, with decent compression you can get closer to 500 whp in a manual trans, 475-480 auto most likely but thats a radical motor. Very hot street deal
408-416 stroker is the best way to make 600+
Old Feb 10, 2019 | 07:22 PM
  #53
Car: 91RS
Re: Rookie on lsx
This is going to take a little longer than I wanted it to. Because I have decided to go ( drum roll )
Boosted and efi...........
Turbo!!!!! Fuel injected... yaaaaaaaaaay!!! I'm on ls1 tech.com and will start learning and asking questions since I now have it home.
goneracin
May 29, 2002 04:58 PM
traumatech
Feb 17, 2002 09:12 PM
TransAm383
Jun 8, 2001 08:03 PM
GTA-Force
Feb 19, 2001 04:25 PM
dacuma
Sep 18, 2000 09:30 PM
