Exhaust advice
Old Feb 8, 2019 | 09:10 AM
draco's Avatar
Car: 1992 Camaro RS 25th Anni.
Engine: 5.0l TBI
Transmission: 700R4 Automatic
Axle/Gears: 3.73 Gov lock
Exhaust advice
https://www.ebay.com/itm/Speed-Engin...S!-1:rk:7:pf:0
Going to run these headers, can anyone recommend a Y pipe or should I just have one made? Going on a stock LQ4 swap with 700r4 now and 4l80e later.
Old Feb 8, 2019 | 11:19 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: Exhaust advice
You'll have to make and fab up your own. There aren't any off the shelf y pipes.
Old Feb 8, 2019 | 11:21 AM
draco's Avatar
Engine: 5.0l TBI
Re: Exhaust advice
That's kinda what I figured. Thank you!
Old Feb 8, 2019 | 11:25 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Re: Exhaust advice
No worries. Luckily there are enough kits out there that you can piece together a decent setup if you can weld.
Old Feb 8, 2019 | 12:53 PM
GASPEDDLER's Avatar
Re: Exhaust advice
LSI/4L60E, system was fabbed from the headers back.
Old Feb 9, 2019 | 12:16 PM
plum92_camaro's Avatar
Car: 92 Camaro RS
Axle/Gears: 10bolt w3.42 Torsen
Re: Exhaust advice
I have Speed Engineering long tubes. I replaced my Racing Innovations with the SE's because they fit better. I had my 3" y-pipe and exhaust fabbed by a top local exhaust shop. Wish I had a pic to post, they did a great job. The way they brought the two 3" pipes together is such a smooth transition.
Kinda wish I'd have looked into one of the dual exhaust set ups. Since a y-pipe has to be fabbed, it can be fabbed to connect nearly any headers to nearly any cat back system.
SMKNGTA
Mar 6, 2002 07:42 PM
1986CamaroIROC-Z
Nov 14, 2001 07:13 PM
Greg Kuhlmann
Nov 9, 2001 05:49 AM
brharris27370
Apr 17, 2001 01:20 PM
Happy17yearold
Feb 24, 2001 04:09 PM
