Any Gen V swappers? Looking into exhaust
Old Dec 29, 2021 | 10:50 PM
TexasLT1's Avatar
Car: '92 RS
I'm looking to reclaim my username and go back with a Gen V LT1. Been putting together a list of the obvious parts I know I need and realized I haven't seen any headers yet. Anyone know what works? Are there adapter plates for LSx headers? Going to have to be something custom?
*ETA: Actually I guess using stock manifolds and fabbing the y-pipe would be the simple route.
Old Dec 29, 2021 | 11:16 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Re: Any Gen V swappers? Looking into exhaust
I've only seen one finished Gen V swap at this forum and the guy couldn't explain much because he didn't do it. I think @LsxMatt has been tinkering on a swap for a while and does all his own work. Maybe look for his thread.
Old Dec 29, 2021 | 11:59 PM
vorteciroc's Avatar
Top Answer: 1
Gen-V SBCs have some drawbacks (but also some benefits) over the Gen-IV SBCs.
Great flowing (for Stock) inexpensive Cylinder-Heads are the main benefit of the Gen-V SBC...
But aftermarket Heads for the Gen-IV, make enough power to not warrant swapping to a Gen-V.
The Gen-V Fuel System is a major drawback.
Old Dec 30, 2021 | 10:36 AM
TexasLT1's Avatar
Car: '92 RS
I'm aware of most of the issues. Haven't seen anything engine-wise that would deter me yet. Having to build custom headers would, though.
Thanks QwkTrip, looks like some good info in his main thread.
Old Dec 30, 2021 | 08:24 PM
vorteciroc's Avatar
Top Answer: 1
Are you deleting the AFM/ DOD System (Lifter Oil Manifold/ Valley Cover, Solenoids and Wiring, and 8 of 16 Lifters)?
You will be adding an Aftermarket Valley Cover and Set of Lifters, for No AFM/ DOD.
Are you deleting the VVT System (Camshaft, Timing-Set, Phaser and Wiring)?
You will be adding a new Camshaft, Timing-Set, and an Aftermarket Timing-Cover.
Are you deleting the Direct-Port Fuel Injection System (Fuel Injectors, Hard-Line Manifold, Mechanical Fuel Pump/ Regulator Assembly)?
You will be installing Pulgs into the Cylinder-Heads (where the Injectors were), a Pump/ Regulator Delete Plate, Fuel Rails, Fuel Pressure Regulator, Port Fuel Injectors, LS Intake-Manifold Adapters, and an Aftermarket LS Intake-Manifold (for Port Injection).
There is a lot more to show, than I posted.
Here is what stock looks like without the Intake-Manifold:
Old Dec 31, 2021 | 02:30 PM
TexasLT1's Avatar
Car: '92 RS
Yes on DOD/VVT, no on DI. It's a toy/weekend car, not a daily driver, and if my history with this car has proven anything, it won't stay bolted together long enough for build-up to be an issue.
Old Feb 4, 2022 | 10:22 AM
O-Crush's Avatar
I believe Hawks is working on swap headers as we speak
Old Jun 6, 2022 | 06:13 PM
TexasLT1's Avatar
Car: '92 RS
Oh man that would really simplify things if so since I've already priced out some other hardware from them.
TooSlow
Apr 12, 2012 10:25 AM
gclay
Apr 23, 2006 09:23 PM
lt1g3n
Jan 6, 2004 04:41 PM
thatsme
Jul 15, 2003 05:21 PM
90RSErik
Apr 14, 2002 09:20 PM
