header options
Old Jul 27, 2023 | 07:29 AM
steve40's Avatar
header options
what is out there for headers now? i changed my direction from turbo to a na stroker.
i have the hooker trans cross member and was following alan's route of the umi k-member with modified hooker engine mounts.
i see that hooker headers for the swap have been pulled from the market, not sure what else is out there that doesn't hang low and would work with what i already have. i am running a 4l80e at the moment.
Old Jul 27, 2023 | 08:38 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: header options
Kooks makes a set as well as Speed Engineering. The later being the cheaper of the two. Hawks also still sells there's as well which I believe are rebranded Kooks. There are also the ebay option which I am positive are the speed engineering units.
Old Jul 27, 2023 | 10:50 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Re: header options
https://www.thirdgen.org/forums/ltx-...-ls-swaps.html
Old Aug 1, 2023 | 07:49 PM
steve40's Avatar
Re: header options
thanks, most manufactures don't have pictures on the car, any advice on ground clearance with the different brands? i want to lower the car and not be stuck hitting everything.
my guess is i would need a 1-7/8 primary for the motor (367 stroker)
Old Aug 1, 2023 | 09:58 PM
thatsupnow's Avatar
Car: 1991 camaro Z28
Engine: Forged 370" LS turbo s488
Transmission: Built 4L80e FTI converter
Axle/Gears: MWC 9" 35 spline 3.25 gears
Re: header options
The entire Hooker setup (headers and dual 2.5") is built for maximum ground clearance
Old Aug 2, 2023 | 09:16 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Re: header options
Ground clearance isn't really an issue with any of the headers, rather its the rest of the exhaust that tends to be hard to keep tucked up. As mentioned, the hooker system fits great, but limits you if you are making above 400rwhp (Per Holley).
Old Aug 7, 2023 | 06:07 PM
steve40's Avatar
Re: header options
I'd go with the Hooker ones, sadly they are not available any more
Old Aug 8, 2023 | 09:49 AM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
Re: header options
They're still out there, you just can't buy 3rd gen specific ones.
Buy them for a pre-smog 2nd gen, they should be close enough to work, might need to dent a pipe here or there.
IRocN87
Feb 1, 2020 10:30 AM
craig
Mar 18, 2011 09:52 PM
HawkeyeGT
Mar 25, 2005 11:33 AM
ThirdGenFire
Dec 25, 2004 02:16 PM
speedlvr
Apr 4, 2001 07:58 AM
