UMI K member + Hooker mount brackets and crossmember
Old Feb 29, 2024 | 09:35 AM
George Klass's Avatar
Car: 1989 Trans Am
Hey everyone. Car is going to get swapped soon and I wanted to use the UMI 2401 K member.
6.0 with a 4L60E and using Blackheart mount brackets and crossmember.
Should be good to go?
Thanks!
Old Feb 29, 2024 | 10:57 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: UMI K member + Hooker mount brackets and crossmember
You are going to need a means to bolt the Holley brackets to the pad on that K-Member. Meaning, the UMI pad is designed to use either their SBC or LSX engine mounts whereas the Holley mounts are designed for the stock k-member bolt pattern. They do not place nice together. I'd run the UMI mounts, since it is designed with their K-member in mind. You can still use the blackheart crossmember even if engine mount positions aren't exactly identical between the two brands. The Holley mounts position the engine a half inch farther forward. While this is fine for the stock k-member, you'll have sump clearance issues with an LS f-body oil pan and the UMI tubular unit (assuming you are running this style pan).
Old Feb 29, 2024 | 12:24 PM
Car: 1989 Trans Am
Hey @ShiftyCapone ,
Forgot to mention I'll be using the 302-2 pan.
I always thought the UMI k member was compatible with stock SBC brackets. Figured the holley ones would just bolt right on. I don't mind if I need to drill a hole or 2 lol.
I don't mind running the stock piece either but the UMI unit looks so good and the extra clearance always helps.
Old Feb 29, 2024 | 01:03 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
The base K-member is sorta universal as they actually call it their small block platform. Their pads accept their LSX mounts #2409 or you can reuse your SBC mounts if you are not going LS. I tried to use OEM LS1 clamshell mounts and it was just too tight of a fit and I didn't like the way the engine sat. I went through a few combos before I just bought all the UMI stuff. The 302 pan will greatly help you when it comes down to clearance. I am running an F-body pan with their road race k-member and there is barely any clearance to the sump of my pan. The sump is around 2" shorter on the 302 pan.
Old Feb 29, 2024 | 01:48 PM
Car: 1989 Trans Am
@ShiftyCapone Then I think I'll probably just stay with the stock K member. The rest of the car is pretty much the UMI catalogue for thirdgens haha.
Old Feb 29, 2024 | 01:50 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
I think this is the way to go. If I had to do it all over again I probably would have stay with the stock k-member a well. Would have been less headache.
Old Mar 1, 2024 | 11:14 AM
Neil350's Avatar
Car: 93 Trans Am
Transmission: T56 Street Twin
Axle/Gears: 12 Bolt 3.90
I run that exact set up, but with an fbody pan. All works fine. UMI K with their mounts, Holley motor mounts. Holley trans mount.
Old Mar 1, 2024 | 11:56 AM
Car: 1989 Trans Am
Hey! UMI mount brackets with holley clamshell and poly mounts?
Old Mar 1, 2024 | 01:40 PM
Neil350's Avatar
Car: 93 Trans Am
Thats right George, UMI LS motor mounts that come with their K, Holley 98-02 mounts with the Polly inserts, ARP bolts to the motor.
jrlanham
Apr 1, 2021 01:53 AM
fbodymn
Sep 10, 2018 10:56 AM
AlkyIROC
Fabrication
103
Jan 10, 2012 11:21 AM
AtreyuBigBlock
Fabrication
Sep 26, 2009 06:44 PM
cooter26
Mar 15, 2008 07:22 PM
