'89 z 75% complete
Old Sep 19, 2007 | 01:26 PM
kerplunk318's Avatar
'89 z 75% complete
here are some pics of the maro, I picked it up for a grand and sold $550 worth of aftermarket parts that came with it. What the guy didnt know is that it had a ktre 12 bolt with 3.73s a posi and a working 700 trans! What do you guys think? Please be critical. I was thinking of changing the stripes they are a little too much. PS I just ordered high polished 17x11 17x9.5 zr1s. And that fp gauge on the hood is gone. By the way those 4 weld scorpios are for sale (tires are trash)
Attached Thumbnails '89 z 75% complete-camaro-pins.jpg   '89 z 75% complete-dsc01046.jpg   '89 z 75% complete-dsc01094.jpg
Old Sep 19, 2007 | 01:28 PM
Re: '89 z 75% complete
The motor in...
Old Sep 19, 2007 | 02:01 PM
Zantasmo's Avatar
Car: '87 Iroc-Z, '91 Trans Am Vert
Engine: 5.7 LS1, 5.3 LS
Transmission: T56, T56
Axle/Gears: 4.11, 3.27
I would keep the stripes.
But hey, it's your car and if you dont like em, take them of.
Old Sep 19, 2007 | 02:37 PM
Demon355's Avatar
What heads are those, Edelbrock Perf RPM's? Car looks good but I would change the stripes to the Heritage style. You might want to install a non A/C box or at least button up those holes in the firewall. All the fumes will come straight in, ask me how I know
Old Sep 19, 2007 | 02:42 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
looks pretty nice, the hood has a rather large gap to the front bumper cover tho and the front gfx looks loose or something with the gap it has.. why not pcv valve? Looks like a nice project, you really lucked out with the 12 bolt!
Old Sep 19, 2007 | 09:03 PM
Yes those are RPM heads. and I am still not sure if I want to run heat so Im deciding on what to do with the firewall. what do the heritage stripes look like?
Yeah i did notice that gap between the hood and the bumper cover do you have any suggestions on how to close that? its a harwood fiberglass piece. And the gfx are not bolted up yet. What is the advantage of running pcv? There is no shot Im passing emissions
Last edited by kerplunk318; Sep 19, 2007 at 09:06 PM. Reason: Automerged Doublepost
Old Sep 19, 2007 | 09:39 PM
IrockanIroc's Avatar
Car: 1989 Iroc z28 TPI Camaro
Engine: 350 5.7 TPI
Transmission: Automatic
i like the stripes if u get rid of those stripes i think u should replace with sum form of striping. stripes are so... camaro. i hated when my dad got rid of the stripes on his 69 but its ok cause my 89 is even better looking lol.
Old Sep 19, 2007 | 09:54 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Heritage stripes look 10 times better on our cars that normal stripes, they're better suited for classic muscle cars, IMO.
Heritage Stripes
Old Sep 19, 2007 | 10:09 PM
Engine: 350 5.7 TPI
i kinda like stripes that go down to the nose though but hey aint my car
Old Sep 19, 2007 | 10:14 PM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
Axle/Gears: 3.23 non posi
I say leave the stripes and fix the hood gap and itll look sweet. Not many people have the down the bumper stripes so its good to see every once in awhile.
Old Sep 19, 2007 | 10:33 PM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Axle/Gears: 9 Inch w/ 3.55
Why do you have heater core lines hooked up and no blower motor box?
Old Sep 20, 2007 | 02:54 AM
I was initally going to run a heater thats why the lines are connected but at this point i am considering not running a heater because the car will only be driven once or twice a week.
thanks for everyones input i really appreciate it
PS, now that i know what they look like... the heritage stripes definately look classier
Does anyone have any ideas on how to fill that gap between the hood and the bumper cover? it looks like harwood just had a bad design on the shape of the front lip of the hood. Will I have to get a body shop to smooth the front of the hood?
Old Sep 20, 2007 | 06:19 AM
ross's Avatar
Car: 82 camaro
Engine: 434 ci
Transmission: t400
Axle/Gears: 9'' 4.10 gear
For the hood gap screw the black plastic ***** down on both sides then back off the two bolts on the latch lower the latch as far as it will go place a rag on the bumper cover where the hood will make contact and adj as necessary. On a side note the large lip on the front of the hood has to be gruond off.
Old Oct 30, 2007 | 07:13 PM
Rocksiroc's Avatar
definately keep the stripes.
Car looks awesome
Old Nov 27, 2007 | 04:23 PM
83Z28BlackBetty's Avatar
Car: 1983 Z-28, Black w/ Silver Stripes
Engine: LT1 350
Axle/Gears: 3.27 9 bolt posi discs
Thats because you have not seen a stripe job done well. I thought the same thing until this...
Old Nov 28, 2007 | 11:28 AM
ZZ4 86 Z28's Avatar
Car: 1986 Z28 Camaro Gunmetal Gray with
Engine: GM Crate ZZZ HO 350, Edelbrock head
Transmission: Rebuilt 700r4 all TransGo and Beast
Axle/Gears: 10 bolt with 3.73 gears
that black camaro is sweet. hey kerplunk, where in md are you anyways? you should get on the mid atlantic boards, id love to see your car in person.
Old Nov 28, 2007 | 11:45 AM
blackbetty are you bashing my stripes? ... well im bashing your wheels; 1994 called they want em back... im messing your stripes look sick. Im in bethesda and you dont want to see my car until the spring time, believe me... i just pulled the dash and console and am currently sorting wires
Old Nov 28, 2007 | 12:58 PM
ZZ4 86 Z28's Avatar
no way, i live right at the rockville/bethesda line. my buddy lives up the street with a low 9 second third gen too. we should all hang out some time in the spring or something and get the cars together.
Old Nov 28, 2007 | 01:09 PM
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Axle/Gears: 3.55 Wavetrac
Really need to run a PCV valve. Takes some pressure off piston rings from gases that build up in your crankcase. Run if off good vacum source like at rear of carb or intake. With out a PCV valve you could have blowback from the crankcase gas buildup, not good for rings and gaskets on engine.
Old Nov 28, 2007 | 01:19 PM
Thanks that was real helpful, im running my booster off the back of the carb, should i just run a T in the line? I havnt looked yet but is there a vac port on the air gap intake?
ZZ im gonna instant message you cause i wanna see ur car and that 9 sec car too
Old Nov 28, 2007 | 01:35 PM
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
I can't tell from the photo of your motor but sometimes on aftermarket intakes they have a threaded hole on the intake plenurm that may have a threaded plug in it. As for running a tee off the rear of the carb, it may be ok or not ok. I don't know if using two devices on that port will affect your brake booster performance. You can try and see. You want the crankcase gases to be burned off, that's why you need to go into the intake/plenurm area.
Old Nov 28, 2007 | 05:07 PM
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
BTW, noticed in the pic you have breathers on the valve covers. This will suffice also for proper ventilation of the engine, however sometimes you can get odors underhood and possible oiling of the valve covers. With a new motor like you have, you won't likely have this issue. Should have noticed before, my bad.
Old Nov 28, 2007 | 05:17 PM
rwdtech's Avatar
Car: 1991 Z28 (sold)
stripes that go over the entire car look tacky. its just too much. i would go without stripes, or heritage stripes.
Old Nov 28, 2007 | 06:34 PM
Engine: LT1 350
Heck no i'm not bashing your stripes! I was just showing some love for "full on stripes". About the wheels...I KNOW! I'm trying to get rid of them but nobody wants them...I wonder why
Old Nov 28, 2007 | 07:01 PM
haha im having the same problem with my weld scorpios, glad i can pick some good fun on these forums
have a good one
6speedIROC
16
Mar 15, 2023 08:33 PM
sailtexas186548
Feb 17, 2017 03:07 PM
Mdenz3
LSX and LTX Parts
Dec 10, 2015 11:18 AM
topteam54
Oct 6, 2015 12:21 AM
MORREALE5
Sep 13, 2015 09:01 PM
