camaro 25th anniversary
Want a title? Post!
Car: camaro ford truck
Engine: 350 vertec
Transmission: 700 r4
i have a 1992 25th anniversary camaro i am building i bought the car about 2 years ago with a bad transmission in it i had it rebuilt and been working on the body of it it has t tops in it i hope the car turns out the way i want it to i was woundering what color red should i paint it back with what kind of rims to put on it it has a built 350 in it body is not that bad of shape just the ground effects is the badest
Engine: Cammed 6.0L LSX
Re: camaro 25th anniversary
Post some pictures up. And a little bit of punctuation goes a long way
It is a 25th.... Get the original rims redone and the car redone to the way it rolled off the floor at the factory. IMO you can't go wrong with a pure stock looking 25th.
Car: 88 Camaro Coupe - 99 Corvette
Engine: 305TPI - LS1
Transmission: A4 - A4
Axle/Gears: 3:73 - 3:15
if its a heritage package 25th... then stock is the way to go! if its anything else, do whatever you please
Want a title? Post!
Engine: 350 vertec
it is a 25th heritage package i am going to leave it stock just re paint it and put headlinear in it
Want a title? Post!
Engine: 350 vertec
the vats system is messing up on it i got to see why sometimes it would start you can go back in 10 minutes and it will start the secruity light stay on when it won't start if it goes out it will crank
Try getting a new key made for it. If the chip in the key is corroded/filthy dirty you can potentially run into that issue. I had the same problem with mine, bought a new key and problem solved.
Car: 87 Camaro
Or you could just do the resistor splice in method, that way you don't need that chip and you could get cheap keys cut instead of expensive ones.
Or you could just buy a new key. Either way
colton_carlson
Mar 8, 2019 12:21 PM
1990, 2011, 25, 25th, aniversary, aniversery, anniverdray, anniversary, anniversaryy, anniversay, bad, body, camaro, camero, transmission
