how can i make my stock 89 camaro faster
Old Sep 5, 2011 | 05:16 AM
89camarojoeb's Avatar
Car: 89 camaro
Engine: 305 tbi
Transmission: auto stock
Axle/Gears: stock
my 89 camaro rs is stock and i want it to be faster. so if anybody got any ideas plz let me no the price and the item. thank you
Old Sep 5, 2011 | 05:27 AM
Car: 89 camaro
Engine: 305 tbi
Axle/Gears: stock
Re: how can i make my stock 89 camaro faster
im new to camaros. so i need so help
Old Sep 5, 2011 | 06:17 AM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Go to Wal Mart in the childrens section and buy a Barbie majic wand - $3.29.
Or, spend a couple of weeks reading the 400 previous threads that cover this topic in detail.
Don't be such a lazy ***.
Old Sep 5, 2011 | 06:29 AM
Grifter757's Avatar
Car: 87 IROC,
Engine: 370 LSx With Boost
Transmission: 4L80E
Axle/Gears: S-60 with 3.50s
As you can see people on here can be *******s. With that being said you gotta give more than i just wanna go faster. i think the best way is to swap in a LS-1 tyoe motor and go from there. But that depends on your budget and such.
Old Sep 5, 2011 | 07:42 PM
Car: 89 camaro
Engine: 305 tbi
Axle/Gears: stock
ok ill quit being so lazy when u stop being such a bi**h.... and to the other guy so what would i have to do to the 350 i got its stock rite now.. what would you do 1st and money don't matter
Old Sep 5, 2011 | 08:10 PM
rob2000gt's Avatar
Car: 91 Trans Am GTA
Engine: Tpi 5.7
Axle/Gears: 3:23
Go to the power adders section and take you pick. The best thing for you to do is spend some time looking at posts of what others have done and decide what is best for you.
Old Sep 5, 2011 | 08:35 PM
LostX's Avatar
Car: 88 Trans Am
Axle/Gears: Posi
loose unnessesary weight.
i just ripped out 30lbs worth of heater components and air ducts from under my dash today
Old Sep 5, 2011 | 08:36 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Do a search on "advancing the timing" and another on "changing rear gear ratio"and one on "Eaton Posi.". Read up on those and you will get a idea of some items that will help you off the line.Adjusting the timing is free, but you will need a timing gun and the knowledge needed to do it right. The gear swap and Eaton posi. cost a little more.To do it right with all new bearings,seals,28 spline axles,28 spline Eaton Posi.,ring and pinion(gears),and install will run you into just over $1,000.00.If you decide to get this up-grade I strongly suggest a L.P.W. Support Cover for the differential. It adds needed strength to the entire assembly.They run about $160.00.I did thees up-grades to my Daily Driver and it makes a huge difference.Love the way it has changed the "fun factor" when I get on it or just driving around town.Pulls nice and hard for a little 5.0.( would also include a "shift kit with Corvette servo. )Do searches on thous up-grades and read as much as you can because your knowledge and installation concerning those items will compliment any and all other up-grades.
Old Sep 5, 2011 | 08:49 PM
Convoy25's Avatar
Car: 95 Z85 S10, 99 Formula
Engine: 4.3 CPI , LS1
Transmission: NV3500, T56
Axle/Gears: 3.08, 3.42
no idea what direction you wanna go so
lose weight, theres an article in the technical articles section on the home page saying all these things you can do to lose weight.
bolt ons will help
a better air intake
under drive pulley
headers + catback, a single 3" will be enough
3.73s or 4.10 gears
higher ratio rockers or a cam
port the heads
battery relocation to trunk to offset weight
shocks and springs to help with traction/handling
LCAs + panhard bar as well
a higher stall converter and a shift kit would be a must
Old Sep 5, 2011 | 09:16 PM
red rock's Avatar
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
The first basic thing to do, is to get a good set of headers and a quality exhaust, at the same time you need to open up the air intake with some KN air filters. More air in, more air out. https://www.thirdgen.org/technical-articles
Old Sep 5, 2011 | 09:24 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
I swear this is not the forum it used to be, people are so immature on here now
Anyway welcome to the forum
Look at the tech articles link on the home page its got lots of cool stuff
Headers exhaust and a open breather will really light it up, a new prom chip works, and the only real chip is one that u pull a chip out to put the new one in not that crap on ebay. Advancing the timing a little helps too .... A good ignition system is nice also
Old Sep 6, 2011 | 12:03 AM
Car: 89 camaro
Engine: 305 tbi
Axle/Gears: stock
thank you all. the only thing that gets me about cars is if i get something will i have to buy something else to make it work right.
Old Sep 6, 2011 | 03:14 AM
justcallmeclassy's Avatar
Car: 1992 Camaro RS Z03 T-Top
Engine: L98 with TBI
Axle/Gears: 2.73...
Last I checked 350s never came stock in an rs....
Old Sep 6, 2011 | 05:15 AM
the solitaire's Avatar
Car: '89 RS camaro 305 TBI
Engine: LO3
Axle/Gears: yep, has those too (stock)
Personally I started in this order:
1, look for all parts that are worn out/broken and replace.
I found quite a lot of those worn out and broken parts in the suspension and brakes. Mostly worn out.
Expect to spend $2500 at least to replace for mostly stock components.
Expect $4000 or more if you decide to upgrade.
With that done, decide on whether you want to stick with the 305 TBI, or if you want to replace the engine. Large part of thsi consideration should go in how much power you want, and your overall budget.
If you live in the US, consider swapping the engine. It might be the cheaper route in the long run.
Old Sep 6, 2011 | 07:56 AM
Car: 89 camaro
Engine: 305 tbi
Axle/Gears: stock
i know but i got a 350 just sittin in a shop and its stock
Old Sep 6, 2011 | 07:59 AM
Car: 89 camaro
Engine: 305 tbi
Axle/Gears: stock
ive already replaces the brakes and some of the smaller thing wrong. but now i want more out of my camaro.
Old Sep 6, 2011 | 08:38 AM
Engine: LO3
If you're on a budget, and think 300 HP / 400 ft-lb of torque will do, stick with the 305 TBI.
In that case best start with an open aircleaner and do some research on headers and a full exhaust. As well as a rear end swap. Something like a 3.05 or 3.42
If you're not on a budget, look into an engine and transmission swap. Still look into the rear end swap
Old Sep 6, 2011 | 09:20 AM
AmorgetRS's Avatar
Auto Detailing and Appearance - Members Rides is not the place for this question. Figure out what you want to do by reading the many thousands of posts on making a Thirdgen faster, then post in the appropriate section.
angel2794
Theoretical and Street Racing
25
Mar 7, 2026 01:08 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Linson
Aug 21, 2015 02:12 PM
Fronzizzle
Aug 9, 2015 01:15 PM
