slowly rebuilding my 88 sc
Old 09-20-2013, 12:56 AM
  #51
JesseShredd's Avatar
Car: 1992 Camaro RS
Engine: 1978 L82 355
Re: slowly rebuilding my 88 sc
Lol!!!! Now that is quite a way to go out. Sheesh. Sorry to hear..
Old 09-20-2013, 08:09 AM
  #52
jdawg1276's Avatar
Car: 1988 camaro
Well it was contained to just t.b.I and down the left valve cover I looked this morning nothing looks burnt but I placed a claim with insurance so waiting to see what they say I think it's eltricle I know can't spell this morning Lol
Old 09-26-2013, 07:22 PM
  #53
jdawg1276's Avatar
Car: 1988 camaro
Well now have to rebuild t.b.I or buy used one which I probably will do but now I think starter is bad or fire broke something else I get a slow grinding noise but it doesn't turn over besides starter what could, it be?
Old 09-27-2013, 11:01 AM
  #54
DiabolicalRS's Avatar
Car: '90 Camaro
Engine: 305 tbi
Axle/Gears: 9 bolt posi 373
get your battery tested, see if its been affected by the fire cause it could just be the battery lost its juice and be weak, or just buy a starter solenoid.
Old 09-27-2013, 12:13 PM
  #55
jdawg1276's Avatar
Car: 1988 camaro
Well swaped batteries with my other car it's the same kind so try a solenoid or whole starter?
Old 10-10-2013, 07:52 AM
  #56
jdawg1276's Avatar
Car: 1988 camaro
well waiting on the founds but order there any fusible links between the battery and started?
Old 10-10-2013, 08:58 AM
  #57
Richboll's Avatar
Car: 89 Black IROC-Z convertible
Engine: 305 TBI
Not sure what this sentence means. Has your auto-correct run amok?
Old 10-10-2013, 09:40 AM
  #58
jdawg1276's Avatar
Car: 1988 camaro
Lol yes it was suppose to say I'm waiting on founds to come in.
Is there any fuseable links between the starter and battery?
Old 10-10-2013, 10:22 AM
  #59
W.E.G.'s Avatar
Car: 88 Sport Coupe Camaro
Engine: V6 2.8
Transmission: Borg-Warner T-5
Axle/Gears: RPO/GU6: 3.42
Diagram of 1988 model "body wiring" from http://austinthirdgen.org/mkportal/m..._continued.gif
Old 10-10-2013, 10:32 AM
  #60
jdawg1276's Avatar
Car: 1988 camaro
thank you that will be a big help is 1990 the same as 88?
Old 10-10-2013, 01:17 PM
  #61
jdawg1276's Avatar
Car: 1988 camaro
o have the starter removed but can't get it out from under the car any ideas how to get it out?
Old 10-10-2013, 02:11 PM
  #62
W.E.G.'s Avatar
Engine: V6 2.8
https://www.thirdgen.org/forums/tech...tarter-my.html
Old 10-10-2013, 04:05 PM
  #63
jdawg1276's Avatar
Car: 1988 camaro
that was kind of helpful guess I'm going to take the flywheel dust cover off and see if that helps because I tried all most all there suggustions?
Old 10-10-2013, 04:44 PM
  #64
Car: '90 Camaro
Engine: 305 tbi
hey uh if you get your car running are you gonna take it to myrtle?
and are you gonna get your starter tested
Old 10-10-2013, 04:48 PM
  #65
jdawg1276's Avatar
Car: 1988 camaro
idk about Myrtle beach with no job it's hard to do anything these days but I would love to go and yes I'm going to get it checked out once it comes out lol
Old 10-11-2013, 08:53 AM
  #66
jdawg1276's Avatar
Car: 1988 camaro
well tried again it ain't coming out so I'm going to see if my father in-law can get it out.
Old 10-11-2013, 08:54 AM
  #67
jdawg1276's Avatar
Car: 1988 camaro
is it normal for a lot of cracks near the drive shaft.
Old 10-15-2013, 07:39 AM
  #68
jdawg1276's Avatar
Car: 1988 camaro
well got it out finally took some time away from it and it fell right out but it has a huge crack along the driveshaft part so I'm betting without even getting it check it's No good plus it's a reman
Old 12-09-2013, 07:44 PM
  #69
Gunnar1's Avatar
Car: 1988 IROC
Engine: procharged stock 350 tpi
Transmission: stock 700-R-4
Axle/Gears: stock 3.27
Good luck with your car....
sleprock
Interior Parts Wanted
10-03-2015 11:01 PM
Spyder_TheGamer
10-02-2015 12:25 PM
hartsmike
10-02-2015 07:11 AM
thejimsterz28
09-30-2015 08:52 PM
Aaronv808
Members Firebirds
09-30-2015 12:55 PM
Quick Reply: slowly rebuilding my 88 sc
