my 84' camaro build. (PIC HEAVY)
Car: 1987 Camaro Z28
Engine: Carbed 355
Transmission: Borg Warner T56
Axle/Gears: 4th gen 10 bolt 3:73 Richmond gears
i found this 1984 berlinetta that i am getting for another project. it is a fully optioned berlinetta. i went to check out the car today. the floors are so rust free its almost impossible. for the car to be sitting on dirt for 17 years, i was just amazed. there is not a spec of rust on the undercarriage. the interior is mint. the car has under 70,000 original miles, and it is fully optioned.
-privacy shade,
-rear cargo cover and lock,
-overhead console,
-full digital dash and stereo,
-power windows,
-power mirrors,
-...power everything
-carpeted black plastics,
-leather and velour seats,
-upgraded interior lighting.
it is an all factory car, never touched.
-hard top, 2.8L,
-automatic,
-complete turbine rims and center caps,
-straight body,
all i have to replace are the doors because the water pooled in the bottom of them due to bad seals and rotted the bottom of them away.
my plans for this car:
-rebuilt 305 engine
-new transmission to withstand the new engine,
-upgraded suspension
-iroc rims
-filled nose holes
-grid tail lights
-posi rear end
-4 wheel disc brakes
-new doors
-new cowl hood
-hawks 5 inch spoiler
-new headliner
im going to pick the car up some time this week. so thats when i will continue the build with many pics (hense the "pic heavy").
-privacy shade,
-overhead console,
-power windows,
-power mirrors,
-hard top, 2.8L,
-automatic,
-straight body,
-rebuilt 305 engine
-iroc rims
-filled nose holes
-grid tail lights
-posi rear end
-new doors
-new cowl hood
-new headliner
1 Post
Car: 1987 T/A WS6 T-Tops/92 RS
Engine: LB9/3.1
Transmission: 700R4/700R4
Axle/Gears: 2.73/3.23
Re: my 84' camaro build. (PIC HEAVY)
Sounds like a cool car, Question? If you going to swap the 2.8 for a V8 then why not a 350 while your at it? I mean it's the same amount of work.
Engine: Carbed 355
yea. i have a 305 that was in my car so we plan to use that one to save money. we are thinking of doing a 383 stroker instead though
Engine: Carbed 355
like i said above. im picking up the car on saturday, starting when i load it on the trailer os when it starts
Car: 1985 IROC-Z
Engine: 355
Axle/Gears: 3.42 10 Bolt Posi
Sry I couldnt resist
Swapping in a 305 will be a huge regret. Dont do it. You can get a 350 for basically nothing these days.
You already doing the work to swap out the 2.8 mind as well put something in thats worth it. Nno one wants a 305
Obvoisly a 383 would be nice but if you look at it from a cost standpoint a 350 will cost you a negligable amoubt more than a 305 while a 383 will soak up more funds and more time
Engine: Carbed 355
probably going to end up doing a 350 or maybe a big block??? it all comes down to budget and money though
Engine: Carbed 355
i looked at the title of the car. i am the second owner of a 69xxx mile car. i worked on it all day today. cleaning it up. inside and out.
on my way to pick up the car
loaded the camaro up
got it home, unloaded it
after some intense scrubbing, i got her all cleaned up. she was covered in moss, tree sap, algae, and of course pine needles and dirt
Engine: Carbed 355
and after the exterior i tackled the interior. all i needed to do was pick up the previous owners trash that has been in there since 1996. got my shop vac out and these are the results. the interior is mint.
ill get some more interior pics soon. next thing i am going to do is replace the hood. the one on it is about to fold in half if i try to lift it up. the bottom of the hood is rusted out. i am going to get an 82-84 z28 hood tomorrow morning and install it on the car. then the rear window louvers. then the doors need to be replaced. all the years of it sitting with crap window sweeps, the water pooled in the bottom of the doors and they rusted from the inside out.
Engine: Carbed 355
well today i found two more mice nests, one in the dash and one under the center console. vacuumed those out,
oh and the dash pad is mint too. the interior of the car is amazing,
i also went to pick up my new hood today. an 82 to 84 z28 hood, and got that on the car. the other hood practically folded in half every time we would lift it up.
i then had to tackle the rust spots on the hood, the paint was bubbling. first i removed the paint around and on the rust
then i POR15'd it so it wont come back.
tomorrow im going to sand it, and apply some body filler and sand that to get it smooth and flush with the rest of the hood, along with a spot on the right scoop of the hood. im also going to put my window louvers on the car, along with removing any plastic trim on the outside like the door trim, and the emblems. looking at replacing the doors next. then the tail lights. and finally the front nose with one off an 84 z28. and of course the engine
1 Post
Engine: LB9/3.1
Not a bad score. One thing I'm not sure how well mud will stick to POR15? I alway mud over bare metal.
Engine: Carbed 355
im goin to sand it down. the por was just to kill any of the rust in the areas where it was pitted.
Engine: Carbed 355
the only reason i por 15's it is because i wanted to stop the rusting and protect it until i can mud it. it was wet out last night, and is goin to rain tomorrow here
Engine: Carbed 355
today i decided since i had very little time, to just take out the interior. i started with the drivers side. i took out the ds seat and then pulled up the carpet. it was very moist under there. the carpet has a rubber bottom, which i have not seen before, and it keeps the moisture from evaporating away if it gets under the carpet. there were some rust spots here and there, more like speckled, i removed the paint on or around them, and on wednesday, since it is going to rain on tuesday, i am going to POR15 it. luckily it is all surface rust. no holes.
i also tried to get it running today. the v6 needs a new fuel pump and since we are replacing the engine, im not going to bother spending money to fix it. it did start up with some some starting fluid sprayed in the carb, we had it running good, and it sounds great, but when we stop spraying it in it just stalls.
this is a pic of the engine before i cleaned it up. ill get an updated photo soon though. now its dark out.
Engine: Carbed 355
i have began to refinish/refurbish my headliner. i wil post pics when im done, its on hold now because of the cold.
Engine: Carbed 355
i pretty much have decided to just delete everything on all of the threads about my new project since no one really cares. CHRISFROM NJ "you should junk it or just stop posting every little thing you do on every third gen website i go on njfboa,thirdgen,and a few other sites and i see your car and what you did to it no one cares" so yea. ill delete this one
Engine: Carbed 355
ill keep this one i guess see what happens
Actually, I'm kinda interested. I used to have an '84 Berlinetta about 10 years ago. Things I remember are the floaty suspension and the crazy interior design.
Honestly, I wouldn't go the route you are. You already have the 350 TBI, so why stuff in another v8 in a car that won't perform as well?
I'd rebuild the 6 or drop in a 3.4L from a 4th gen. It's a direct bolt in. Put in a T5, chrome the stock wheels, find tires with an even bigger white wall, slap on some louvers and have yourself a fun to drive cruiser. Leave the speed for the car that's already a v8. Otherwise, you're looking at the hassle of a v8 swap into a car that still wont handle like an IROC.
Engine: Carbed 355
im lookin at v8 305 with upgraded suspension, upgraded transmission, posi rear end, sportline springs, and navy blue metallic job. with silver rockers/gfx. i think im gonna do the paint myself with this car but actually try this time. on the weekend im going to pick up an 82-84 z28 nose and chin spoiler. along with a new carpet, some grid tail lights, and possibly some new doors. then its time for me to start to save for some iroc rims or some american racing wheels
Engine: Carbed 355
i asked him to do that actually. mike is a pretty good guy for doin it... many actually want to see my progress, its just you dont so just get out of here and stop bothering me.
Car: 72 nova/ 90 camaro rs,04 suburban
Engine: blown 327/ 355/306/355/5.3
Transmission: muncie 4 speed/T5/powerglide,4l80e
Axle/Gears: 342/411/456/ moser axles
i honestly would have just said look at this, what i picked up, and then not posted a thing besides a few questions until it was finished. i only did it kuz people told me to. id rather not even do it to tell you the truth because it just takes too much time and effort to stop what im doing and take pics. just a waste of my time but i did it kuz someone told me to. so screw off and stop bein a jerkoff to a kid
Car: 1984 Camaro Berlinetta
Engine: 355
Axle/Gears: Australian 9 bolt 3.27 posi
Mac86,
I have the same car, well I do but you can't tell. Mine was the same with the exception that mine had t-tops. I love these cars and always have. I have done a ton of changes to get to where I am today and seeing your car and your love of the car to me is inspiring. Great thread man. Haters be hating. That's just the way it goes. I for one am subscribing and want to see where you go with this. A moderator should intervene here and remove this individual as he has added nothing but conflict to your thread. Good luck with the car Mac.
COTM Editor
Glad to see the thread cleaned up. Back on the progress with the saving of another third gen!
1 Post
Engine: LB9/3.1
I like like the car and think it's cool that your working on it so hard, if I would on my RS half as much as you work on that car it would be done LOL!
Car: 83Z28 HO
Transmission: G Force 5 speed
Good to see progress on your car! I'm getting ready to get off my dead A** and work on mine here today. Rumor has it that spring is near....never know it around here since it's a high of 34 degrees today with snow/rain mix.
Cleaning up the engine before you yank it out?...or are you going to get this one running?
In the end, posting up detailed progress pics is a good thing...it's the detail stuff that raises questions on the board..i.e. "how does this clip thinga-ma-jig fit on"..etc. If you don't delete or move your pics, it'll be there for years for others to reference. Not a bad thing IMO.
My car rose from the dead too...I didn't own a digital camera back then. I had the same surface rust under all my original ground FX...metal was just pitted and not rusted through at all. In my case, I figured it was better to just preserve all those areas real good to stop any further rust and put the FX back on after it was painted.
Car: 91 Camaro RS, 84 2.8 5speed
Engine: 305 5.0L
Transmission: Auto, 5 speed
Very nice find man, i love those seats! The car is so clean, can't wait to see the swap!
Engine: Carbed 355
did some experimenting with a scrap tail light
Engine: Carbed 355
yea i did not wanna mask the reverse parts since its just a scrap lense that cracked. on the actual ones im going to
Engine: Carbed 355
today's update:
re-covered my headliner.
what it looked like previously:
got it out of the car, and took off the fabric and used a shop vac to get the old foam off
peeling off the old glue:
then i got the new fabric in the mail, and applied it with headliner glue and trimmed. here is itfinished
its not show quality but its good enough for me. id say its pretty good for the first try.
here are the sail panels. they look perfect
headliner semi installed:
Engine: Carbed 355
i began to rebuild/refurbish the tail lights. i only got one done today.
the refurbished one is on the left. i still need to buff it and polish it one more time
i repainted the inside of the housing since the paint was poorly done and peeling
here is the old one
and then after everything was cleaned up i felt like taking a pic
tomorrow im going to por15 the floors, and finish my tail light refurbishing on this car and my black one
here is the old one
Car: 84 SC Camaro (92 Tribute)
Engine: V6
Transmission: M5
Hey man. Your cars looking great. I've always like the digital dash F-body's. They are definately 80's cool. Mine is an '84 too, but not a Berli... I would love to have one though. It's different and to me, that's cool.
Engine: 355
Cars are looking good! Nice interior work there. What's with the license plate placement? Would almost look better in the windshield. A camaro grill insert would fit that car perfect.... like this one.
the one pictured is a bit beaten up but you get the idea.
#42
Engine: Carbed 355
https://www.thirdgen.org/forums/fabr...ate-mount.html
#45
Engine: Carbed 355
haha idk. the cover blew off of it when it was raining and i had to put it on wet. then i took the cover off today and it all started to come up haha. each layer of paint is so thin though. there is no clear on the car, the white is extremely thin along with the primer and primer sealer its like gm didnt even paint this car right.
#46
1 Post
Car: 1987 Sport Coupe
Engine: Carbeurated 5.7
Transmission: NWC T-5
Axle/Gears: Non-posi 2.73
Onthewindow, where did you find that grill insert? I need one to my 87 sport coupe and all I can find is one for z28/ iroc and those ones are too big.
#47
Engine: 355
Here is the url to the auction....
http://www.ebay.com/itm/85-90-CHEVY-Z28-CAMARO-IROC-GRILLE-FRONT-RADIATOR-WHITE-CAMARO-LETTERING-/221213253175?pt=Motors_Car_Truck_Parts_Accessories&fits=Model%3ACamaro&hash=item3381565e37&vxp=mtr
hope this is what you wanted.
#48
Car: 84 Trans Am, 84 Fiero, 86 944
Engine: 5.0, 2.5, 2.5
Transmission: 5spd
nice build, just like to say that car has the best looking interior you could possibly get in a thirdgen, and howrare you have the tweed/vinyl seats with no rips or tears, and a working digi dash, great car, glad to see it saved
#49
It's been very interesting following your build. I am in the process of restoring my 84 Berlinetta. It has sat for 13 years without being driven but in a dry climate and I covered all the zebra pinstripe seats to protect from sun damage. Mine has the same colors as yours. I am learning it's going to be a challenge dealing with the digital dash. Couple things are wonky now. They may come back on. This is the first week I have driven it in 13 years. The blinker came on as my mechanic/friend said it could. I truly love the car's
dash. You seem very enterprising and I'd like know how you plan to revive the dash if you start to have problems with it. I know there are parts out there but I am unsure of that
situation. Got everything lined up to have it worked on, but I need to know the dash can
be worked on. Have you researched that at all?
Thanks for all the pics.
#50
Engine: Carbed 355
mine is an extremely low mileage car, the dash is in 100% working shape has 0 problems
