Bomz CAI install
Old May 3, 2008 | 12:40 PM
The White Knight's Avatar
Car: 1983 Trans-Am
Engine: 305 5.0 LG4
Transmission: 200C 3 Speed
Axle/Gears: 2.93 Open Diff
Bomz CAI install
Intake is on, looks 10x better, sounds so good aswell!!
Old May 3, 2008 | 02:42 PM
TA5point0's Avatar
Car: 89 trans am
Engine: 305 tpi
Re: Bomz CAI install
looks nice..whered ya get it?
Old May 3, 2008 | 03:10 PM
Stephen's Avatar
Car: 87 GTA
Don't you mean HAI? Other tan the tubing size & hi-flow filter, you haven't gained anything but increased flow.
Old May 3, 2008 | 03:47 PM
Bounty600's Avatar
Car: 89 Firebird
Engine: 5.7L V8
How much did it cost to get the top of the engine painted black? I wanna get mine painted chrome
Old May 3, 2008 | 04:10 PM
Car: 1983 Trans-Am
Engine: 305 5.0 LG4
I did it myself.. so nothing. lol
Old May 3, 2008 | 04:31 PM
87 formy's Avatar
Car: 87 formula
Engine: 5.0 TPI
There's no need to get it painted chrome when you can just polish the aluminum
Old May 4, 2008 | 07:43 AM
89transam*pearl's Avatar
Car: 89 T/A
Engine: LB9
Transmission: W/C T-5
Axle/Gears: 10 bolt posi, 3.73 Richmond Gears
I've been running mine now for the last 3 weeks and it doesn't run any hotter than the OEM cold air system...I'll update that in July/Aug when the hot weather arrives....
Last edited by 89transam*pearl; May 4, 2008 at 07:47 AM. Reason: Automerged Doublepost
Old May 4, 2008 | 08:30 PM
Shift06's Avatar
Car: 1991 Trans Am GTA
Engine: LSX (swapping)
Transmission: 4L60E (swapping)
Axle/Gears: 2.73 Posi 10 Bolt
ha, I have the same intake, and my TPI setup is painted the same too . I didnt notice a difference in sound though.
Old May 4, 2008 | 08:43 PM
gcgarner's Avatar
Car: '92 T/A WS6 Vert/1956 Chevy Nomad
Transmission: 700r4 w/ Transgo Kit
Axle/Gears: 3.42 LSD
Stephen, we get the point ...
You say this on every post similar to this.
I agree that it's not the best idea for CAI, but it is a lot better (looking and flowing) than stock.
Old May 6, 2008 | 06:31 AM
avro206's Avatar
Car: 89 Formula
Transmission: TH 700R4
if some one would track test it....if it gained I'd buy.
Old May 7, 2008 | 04:22 PM
90CamaroTBI's Avatar
Car: 91 Formula, 89 IROC
Engine: LB9, LB9
Transmission: 700R4, 700R4
Axle/Gears: Posi 2.73, Posi 2.73
There is no way it wouldnt gain, the stock intake, my lungs could not breath through. I have the same intake and it for sure made a small difference. Since my a/c stuff is out there are gaps in front of the radiator where I can see cold air coming to the filter, or at least not hot air.
Old May 7, 2008 | 04:33 PM
Stephen's Avatar
Car: 87 GTA
Yes, I do. That's because he is now sucking 100% HOT air, instead of geting the filter near a coooler air source.
Cut a hole below where that filter is, stick the filter down there THEN you'll be acheiving CAI. A little more work, but cooler air is more oxygen (what our engines need) dense. Therefore, hotter air essentially equals less air, in regards to what can be used.
Old May 8, 2008 | 04:09 AM
Car: 89 T/A
Engine: LB9
Ya gotta admit....he's consistent !!
Old May 10, 2008 | 10:59 AM
mean57's Avatar
Car: 87 gta
consistant and correct!
Old May 18, 2008 | 01:39 AM
1bdbrd's Avatar
Car: 1991 Trans Am
When I originally bought my 91 it had a k&n stuck on the throttle body. I replaced that with a pvc setup similar to the OP. Noticed absolutely no change in performance. That was also backed up by track outings. Then I swtiched to the single inlet SLP CAI and again noticed NO change. Again backed up by track times. Colder air is better, but I think more hotter air is better than less cooler air.
Example, if you were to run through the desert with small piece of pipe sealed to your mouth, you would make it further than running through the tundra with a coffee straw sealed to your mouth. Restricting your intake in the name of cold air isn't always the smartest idea.
Old May 18, 2008 | 07:07 PM
FormulaL98's Avatar
Car: 88 Formula, 72 Nova, 68 Chevelle
Engine: L98, mild 350, L79 327
Transmission: 700R4, M20, M20
Axle/Gears: 9b 327,10b 373, 12b 331
It does make alot of sense to have the filter drawing air from a much much cooler outside source. the Bomz "CAI" looks to be your sterotypical import durived intake. The filter being that close to the radiator cant be doing anymore for performance than the stock set up. the SLP set-up is the way to go besides making your own induction system, when my car was stock with no other mods the SLP intake dropped me .3 in the 1/4 mile (from 14.6-14.3) and looks dead stock.
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Apr 25, 2017 07:14 AM
dennisbernal91z
Fabrication
29
Mar 2, 2017 12:04 PM
gixxer92
Sep 1, 2015 04:32 PM
86IROC112
Aug 17, 2015 07:57 PM
